Old 07-29-2005, 11:55 PM   #1
no fuel pressure
my lebaron has been sitting way too long. about a year ago i went to start it and had no fuel. so i replaced the pump with a walbro. worked great. that was the last time i drove it, went out today fresh gas, fresh battery cranked fine but fuel pump not running. i assumed it's probably a relay. went to the dealer and they can,t find a fuel pump relay listed or an asd relay for my year(1987). any ideas or thoughts? and i do know what happens when you assume. couldn't check for power at pump it started to rain. i really want to drive my turbo again. thanks
t-1 LeBaron 5sp is offline
Old 07-30-2005, 11:13 AM   #2
My Ride: GLHS Charger
Are you getting spark at the plugs?
MVaughn is offline
Old 08-23-2005, 09:29 AM   #3
Finally got back to my car. I have spark. checked for power at fuel pump--if I put a volt meter probe in each socket of the pump pigtail I get cranking voltage (9.9 battery is low). I hear a slight click from pump but it doesn't run. Bad pump. Should I try another walbro or go stock? BTW walbro cheaper than stock. Thanks
Mortgage Calculator | Guitar Lessons | Credit Cards | Christmas Gifts | Guitar Lessons
Page generated in 0.33055 seconds with 13 queries
