08-17-2005, 11:51 PM
My Ride: 88 Shelby Z
Engine: 2.2L TII 175hp
I assume there is emissions in north carolina and your not aloud to remove any pollution control devices? (typical canuck question)
If you have any mechanical know how at all this shouldnt be to hard.
88 Lebaron Turbo. If it doesnt need to get safetied or inspected in the next while this is what you can do. What id do is rip all your lines out and put them in a pile on the floor. If its old brittle hose go grab some new stuff! If not you can just reuse the old stuff if its needed.
If you absoultely need the emissions stuff hooked up, you might be able to just make it look like its hooked up the day you take your car to be inspected and emissions tested.
Youll have to find where you want to run all the hoses from. Should be a spot on the intake you can start from. You should only need these lines.
Brake booster - Should run from the back of your intake (behind the throttle body) over to your brake booster.
Fuel Pressure Regulator - Should run from the vacumm source on the intake over to the FPR.
Map Sensor - Should run from the vacuum source on the intake over to the map sensor. Usually runs along side the FPR hose.
Boost controller - This depends on what your running.
If your running a manual boost controller, it goes from the vacuum source, to the MBC (g valve) to the wastegate actuator on the back of the turbo.
If your running the stock boost solenoid, the vac hose comes from the source on the intake, over to the boost solenoid on the passenger side fender, then from a different port on the boost solenoid (youll have to take a look at whice ones) over the motor then down to the wastegate actuator. (grey can on the back of the turbocharger... (I dont have this setup so if im wrong someone please correct me lol)
Both ports on top of the TB can be capped off.
