08-22-2005, 11:45 PM
throttle stuck
My Ride: 86 shelby charger
wtf like i strart my carand all the sudden seems like i got a stuck throttle right at 2800rmps i checked my distrubuter its fine and moved my throttle cable on the intake back and forth it still does it
08-23-2005, 01:05 AM
come on guys i need to fix this
08-23-2005, 01:08 AM
86 sc turbo 1 just idles at 2800 now all the sudden
08-23-2005, 01:09 AM
the distrubtor is in place from when i first set that timing and it just all the sudden started doin this when i was driving tonight i duno wtf to do
08-23-2005, 01:17 AM
yea all the sudden it started pulling weird all the sudden i was like wtf then it started in and out of gears stay at 2800 rpm
08-23-2005, 01:26 AM
today i loosend it and set the timing where i wanted it, i didnt fully tighten back up like hell and left it to were if i needed to move it i could tap it with a hammer
08-23-2005, 01:37 AM
illl check the plate in the morning, no before it idled lil over 1k so i moved the distributor and set it right under 1k then all the sudden tonight seems either like its idle n at 2800 or throttle is stuck its dark out and i dont have a flashlight or tools to get to right now i can pull the cover off the throttle bodie, another question since i removed the stock airbox and ut a air filter cone on for now that ill use once i do the t2 conversion for my turbo, the hose that went into the box is just sitting their suckin in air should i let it or block it off
08-23-2005, 01:38 AM
#12
You have a vacuum leak! You need to trace all your vacuum lines carefully. If this comes up empty, get some needle nose pliers and pinch off the booster line-if the idle drops, your booster is junk. If not, keep searching. Of course, make sure your throttle is closed.
08-23-2005, 01:40 AM
#13
read the post i just put also how come it all the sudden started that then
08-23-2005, 01:46 AM
#14
Changing your timing won't make the idle go to 2800 rpm.
