08-23-2005, 12:41 PM
Sounds like wheel bearing to me. There might be some play in the wheel (drive wheel, not steering wheel). A bad bearing won't generally cause a pull. My neon wheel bearing howled for 5000+ miles and showed no play.
Depending on who does the bearing and how they do it, you may or may not have to get the car re-aligned. My 85 FSM shows a chrysler tool that pops the bearing out with the knuckle on the car. Otherwise, mark the camber carefully where the strut bolts to the knuckle and pull the knuckle off. I have seen people remove the knuckle with the strut attached, but never done it this way myself.
william
