Hey guys, I have a noise coming from the front side of the car, radiator side. It is a whining kinda noise and isn't always present. Tracked the noise down by pulling off all the belts to isolate it. Does the distributor shaft tend to do this? It has a miss on and off that I cant get rid of also. All new tune up parts,did it prior also. Thing is fixed leaking oil pan and found oil pick up tube plugged with rtv, the whole screen. Im hoping it didn't do any damage, Oil press. seems ok on gauge just like before. Hoping it didn't wipe out the balance shafts from starving making my squeal and poss. stumble. As plugged as it was I don't know how it didn't cause any damage. Any ideas? Dist. shaft seems ok. Thanks Allan
