04-24-2006, 01:29 AM
Originally Posted by mattn124
Had no idea that was the feed,, it points down and is a good diameter so i just assumed it was the drain side, thanks for the tip.
I'll just try the parts store hoses first. Only concern is that this hose is on a kind of housing that bolts onto the turbo,, so hopefully i can seperate them without any damage,,
Maybe I;m describing the wrong piece, but a hose with a 90 bend in it will not fit here,,,
My cars' an 85 SC, got a 2.2L turbo 1 in it
thanks for the replies
Well, its a soft 90 deg. You simply grind off the crimped fittings with a grinder and slide the rubber hose off.
