Old 05-09-2006, 08:14 PM   #1
How much boost is the stock and walbro fuel pumps good for?
How much boost is the stock turbo fuel pump good for? Also, I've heard the in-tank walbro 255's are good for all the boost I'd ever want to run, but are the in line walbro 255's as good? My brother wants to run one of the in-line's in his rampage, just wondering how much it's good for.
DaytonaTurbo87 is offline
Old 05-13-2006, 06:24 PM   #2
stock turbo fuel pump is good for no more than 15 psi, according to most people here. I wouldn't push it and risk leaning out.
f3likx is offline
Old 05-13-2006, 08:06 PM   #3
GTCUL8R
Polygon's Avatar
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Images: 59
It is 14.7 to be exact I believe. Anyhow, if you want to go past that you will want to get the Whalbro pump and bigger injectors at the least. As far as I know there should be no flow differences between the in-line and the in-tank pumps.
My CarDomain Garage
Polygon is offline
Old 05-13-2006, 08:11 PM   #4
My Ride: '89 Daytona Shelby
Let's see ... that's 255 litres an hour or 67 US gallons. That amount of fuel will support over 600HP .... hmm, how much boost is that?
puppet is online now
Old 05-13-2006, 10:06 PM   #5
My Ride: 1991 Spirit R/T
Engine: TIII 2.2
the stock pumps flow 255 lph?
Dr.Evil is offline
Old 05-13-2006, 11:57 PM   #6
Feedback: (32)
Stock is 165... or something like that.
tryingbe is offline
Old 05-14-2006, 08:20 AM   #7
If the stocker can support 260-270HP then the flow works out to about 102 lph or 27 gallons.
Old 05-14-2006, 08:26 AM   #8
My Ride: 1986 GLHS #126
Engine: stock
above is good reference data but actually if you are serious about making sure your not running out of fuel you should not just depend on a high volume pump and larger injectors, you really have to measure the resultant air/fuel ratio because there are so many factors that effect it. remember also that too much fuel is not good either.
Marcus86GLHS is offline
Old 05-14-2006, 02:12 PM   #9
The stock pump is a 160 or 170 LPH, can't remember. You can make it flow by pinching off the return line, I did that for one summer, got 18psi out of it stock injectors and 3 cold starts. If your considering turning up the boost, just get the 255, there not much more than a stock one and the stocker is probably on its way out anyway. Intank is easier as you just drop the tank, a few minor mods on some cars/vans and away you go.
Old 05-14-2006, 02:33 PM   #10
GTCUL8R
Polygon's Avatar
Images: 59
Does anyone know the easiest way to make sure that the Whalbro pump you just bought is a 255lph pump?
My CarDomain Garage
Polygon is offline
Old 05-14-2006, 02:57 PM   #11
If memory serves, there should be a part number on the housing.
Old 05-14-2006, 06:06 PM   #12
Those stock FP flow rates can't be right fellas ... stock pump wouldn't support the 300HP S60 package which requires 115+lph.
Old 05-14-2006, 06:19 PM   #13
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
I ran 16psi on the stock pump and lines and filter. Motor's still running. I now have a 255 and running 18-20psi.
Dave is offline
Old 05-14-2006, 08:29 PM   #14
It doesn't, you MUST buy the S60 inline 60 gallon/hr pump or buy the intank Walbro,
Credit Cards | Personal Loans | Credit Card Consolidation | Debt Consolidation | Bankruptcy
Page generated in 0.44200 seconds with 13 queries
