If the transmission in your car is the stock transmission, than it is not an A525. The A525 was only used L bodies for all years, and in other bodies up until 86. Stock 5 speed for non-intercooled turbos and N/A 4 cylinder motors in 92 was an A523, which is about as strong as the A520, minus the A520/A555's weak bearing plate.
At the very least you would need to swap out the wiring harness and computer for a turbo motor. So it is good that you have those items. I don't know how difficult it is to swap/modify 92 to electronics, since I haven't messed with them.
I am confused about what you want to do though. You said you have an 89 T-II motor. How much of the motor do you have? A complete long block, including manifolds? Less than that? Are you wanting to swap in the 89 T-II motor into your car, or are you looking at putting the turbo setup on the 2.5 motor you currently have in your car?
If you are going for the latter, let me advise you not to. The N/A motors run higher compression pistons than the turbo motors do. Plus all OEM pistons (except for the rare DOHC turbo motor) are cast. Cast pistons do not tolerate detonation very well at all. You can turbo a motor that is using these pistons, but it is dangerous. You will HAVE to use premium fuel, and probably run lower boost to avoid destroying the pistons from detonation, and even then, if your tune isn't spot on, you may destroy them anyway. This isn't to say it cannot be done, or hasn't been done. It just isn't a good idea.
If you want to swap out the N/A motor for the T-II motor, then you will still need to swap in the turbo electronics that you have. You will also need to swap out your fuel pump, as turbo motors got one that flowed more than N/A ones did.The motor will bolt up to your transmission without any trouble, but I believe that the turbo motors got stronger clutches than the N/A ones did.
If you want to upgrade the turbo and IC when you chang over to turbo, then it would be a good idea to decide on how much power you want to make. Try to figure out in detail just what you want it is you want to do, from goint a bit faster than stock to building a race car to challenge others at the racetrack. Spend some time reading up on the forums (the "Search" button is your friend here), talk to the various venders that support our hobby, such as
Turbos Unleashed and
FWD Performance(they will be able to answer lots of questions), read
The Dodge Garage and the various sites linked from there. When you've read up on the subject and know exactly what your goals are, it will be easier to pick the correct turbo, intercooler and any other upgrades that may be necessary.
Just how far are you looking to go with your setup?
