Old 05-15-2006, 07:32 AM   #1
Which cam to break the motor in
I was just thinking that since the cams are pretty easy to swap out, that I should break in my built 3.0 with the stock cams. Im not sure how its gonna run with the new cams and I would like no problems when I seat the rings.
the stockers are 182 adv ~135 @ .050" and 350" total lift
new cams are 278 adv 216 @ .050" and .450" total lift.
Im guessing it wouldnt hurt anything to run the stock cams for seating the rings and the first couple hundred miles. I dont want to have to deal with drivability problems while also worring about the rings.
Ondonti is online now
Old 05-15-2006, 08:42 AM   #2
that is just plain goofy!!!!! just build the engine as you intend to use it. If I was to follow your strange idea, I would have wasted an awful lot of time. do you think Roush engine builders do that? hell NO
allmotor is offline
Old 05-15-2006, 01:50 PM   #3
Haha, Im sorry,
My n/a 3.0 is faster then the roush Mustang GT that ran at the track 2 weeks ago.
I know you know A LOT about building motors but your response is absolutely not helpful since you are ignorant of 2 things,
#1 Total Seal said no boost on my rings when I seat them, beat on them sure, but no boost. I could go ahead and dump boost into it and get a pos that burns out like simon.
#2 My cams are bigger then RPW (australia) stage 5 cams (their largest/race only) and I have no idea what the car will run like on stock computer. I have a standalone but That would be even worse since it would have no base maps.
Old 05-15-2006, 02:14 PM   #4
Feedback: (32)
No boost on new rings?
I guess all the turbo dodge and SRT4 and every other FI cars have bad sealing rings...
tryingbe is offline
Old 05-15-2006, 03:57 PM   #5
I am using a $300 Set of Total seal rings (designed for import turbo drag cars blah blah) which are NOTHING like your or my stock rings and I was told absolutly NO boost when seating them. Most cars that use rings like these probably make no boost in the first 5000-6000 rpms because of their huge turbo so they can get away with things I can not.
Record Internet Radio with Tags | Mortgage Loans | Loans | Bankruptcy | Mortgages
Page generated in 0.38179 seconds with 13 queries
