Old 06-07-2006, 11:22 PM   #1
can anyone help??????
im having a prob with my 86 glh.i just got the motor back together and it wont start.it has good spark and plenty of fuel.i think the timing is off but i need some opinions.also wat should that car with a mp computer inatke and exhaust run at the track? thanx guys
srt_wut omni 86 is offline
Old 06-08-2006, 12:02 PM   #2
My Ride: 88 Shelby Turbo Z
im guessin yor distribtor is in 180* off. elevation depending 14-15
Colorado Z is offline
Old 06-08-2006, 12:21 PM   #3
My Ride: 1987 Dodge Omni
Engine: 2.2, later 2.5 turbo
^ very common, also my guess assuming you have compression and fuel.
when you start an engine you need fuel, compression, and spark and the thing that's always forgotten is the timing of the three.
Omnivore30psi is offline
Old 06-08-2006, 01:45 PM   #4
in which order ar the cylinders numbered?
i though it was 4 1 3 2 ?
Old 06-08-2006, 09:16 PM   #5
i thought maybe it is 180 out too but i have moved it around a few times so i know its not in the same spot.i jus cant figure it out ???
Old 06-08-2006, 09:51 PM   #6
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I struggled with that too- I had 2 marks on the Flywheel for TDc, of course I picked the wrong one intially!!
go here for help:
http://www.thedodgegarage.com/timing_belt.html
dyno sheet
fmic install:
crazymadbastard is offline
Old 06-08-2006, 10:00 PM   #7
thanks for the link.i actually jus printed that out earlier.how easy is it to do if u go by those instructions?
Old 06-08-2006, 10:20 PM   #8
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
pretty easy, just double check the flywheel mark. Mine had 2 and I was off 45 degrees or so - it tryed to start but not quite. Good luck, let us know when it runs and what was the matter.
dyno sheet
fmic install:
Old 06-08-2006, 11:04 PM   #9
ok thanx.i hope to get it running by this weekend so maybe i can make it to the track.i was kinda dissapointed last weekend when i couldnt figure it out.
Adverse Credit Remortgage | Bit Torrent Downloads | Mobile Phones | Loan | Debt Consolidation
Page generated in 0.42283 seconds with 13 queries
