05-31-2007, 02:44 PM
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
I'd also pull the two plug ins on the HEP sensor. That way if you're cranking the engine over with the starter you won't be sending fuel into your engine and getting gas in the oil. I'd also suggest you fill the oil filter with oil and also crank the engine with out plugs and with the HEP disconnected until the oil light goes off in the car. Then fire it up and let it run 10 minutes then change oil and filter. There's a couple schools of throught on breaking in a motor and one school is to ride the motor hard for the first 20 miles to seat the rings properly. The other is to take it easy. I'm not an expert in this so I can't comment. I broke mine in on the easy side and everything seems to be okay.
