08-09-2007, 05:11 PM
My Ride: Saratoga -93
Engine: 3.0 V6
Ok, thanks for the offer but i found the problem and something to fix it, for now at least..
It was easy to take out, just one bolt open from the other side of the bracket, and it came out.
Now the problem was, that the steel plate, that holds the tensioner together, had bent and made it loose.. So the pulley would twist to the right/down a bit. Now there is a hex screw in there to tighten it, but it had stuck on mine so i couldn't use it. So i solved it just by placing two small steel sheets as a spacer between the lower part of the tensioner and the bracket. This would correct the tensioner position just enough to make the belt run in correct alignment.  Now the belt stopped squeeling right up.
But i guess the best solution would be to adjust the screw if someone else has this problem..
