Old 08-11-2007, 12:17 AM   #1
Low oil pressure? help
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
Every once and a while when my car is ideling my check enigine light will come on with my low oil pressure light. If i get the the rpm's up the slightest bit then it goes away. Anyone have any idea what might be causing this? IS it anything to worry about? Any help would be much apreciated.
Thanks
Brendan
Turbo-Baron is online now
Old 08-11-2007, 12:28 AM   #2
My Ride: 90 doge shadow
Engine: 153,2.5 L
Feedback: (-2)
are stock gauges get old and they don't work right and they have false readings so get u a mechical gauge and then tell us what the reading is.If it's loiw then it could be a weak oil pump or bearing clearnce
scottsshelby is offline
Old 08-12-2007, 12:15 AM   #3
My Ride: 1989 Shelby Daytona
Engine: 2.2 liter turbo 2
Also, even though this is unlikely, but also a possibility, you should for the hell of it check the components of your oil pump. Such as making sure the part of the timing belt that goes around the intermediate shaft gear is nice and tight and check to make sure your intermediate shaft is turns freely and is not obstructed.
Moparkid2.2 is offline
Old 08-12-2007, 01:04 AM   #4
if it is pre-90 (or 89? dont remember) then it is probably a bad oil pressure sending unit. On the earlier cars, the computer and the gauge were on seperate sensors, so you would get bad readings on the gauge but the CEL would not come on. On the later models, the same sensor provides the signal for both the computer and the gauge so it will trip the CEL. The sensor having a worn out diaphragm is by and far the most likely reason for your problem. The sensor is only 10 bucks or so at mopar.
Gumpus is offline
Cheat Codes | Guitar Lessons | CreditCards | Remortgages | Credit Cards
Page generated in 0.31167 seconds with 13 queries
