What octane do I need in my 03 stratus coupe r/t 3.0 v6? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 14 Old 09-09-2007, 02:58 PM Thread Starter
Red face What octane do I need in my 03 stratus coupe r/t 3.0 v6?
My choices I think are 85,87,89 and 92/93.
Which does this car need?
If it only needs, say 89, what will putting 93 in it do? Speed it up? Engine longevity?
Thanks guys!
xenium is offline
post #2 of 14 Old 09-09-2007, 03:07 PM
TD Hardcore User!
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
I find with higher octane gas comes better performance and better gas milage.
Turbo-Baron is offline
post #3 of 14 Old 09-09-2007, 05:14 PM
Just A Guy
NAJ's Avatar
Use of a higher than recommended octane will not give any performance or mileage increases.Octane rating is the gasolines ability to resist detonation and that is all.Since higher octane gasolines require more heat for the combustion process a vehicle that is not designed for such may develope driveability concerns.
Here is a TSB sent to Chrysler Dealers a few years back on this subject.
14-08-97
SUBJECT: Poor Driveability With High DI (Driveability Index) Fuel
DATE: Nov. 21, 1997
SYMPTOM/CONDITION:
Long cold start times, warm-up sags, hesitations, and driveway die outs. These symptoms are most noticeable and severe at moderate ambient temperatures between 4 - 27 degrees C (40 - 80 degrees F).
DISCUSSION:
Gasoline with a high Driveability Index (DI) can cause the above described symptoms. DI is a measure of the gasolines total volatility, or tendency to vaporize completely. A high DI number is less volatile than a low DI number. Most premium gasoline sold in the U.S. has a higher (worse) DI index than regular or mid-grade gasoline. Use of premium gasoline is NOT recommended for vehicles designed to run on 87 (R+M)/2 regular or 89 (R+M)/2 mid-grade gasoline. High DI gasolines also cause higher emissions for the same reasons they cause driveability problems.
For vehicles that require an octane rating of 91 (R+M)/2, premium is recommended, or possibly required. Using premium fuel with a higher than recommended octane rating is not recommended. Owners who experience fuel related cold start and warm up driveability problems should try a gasoline with the recommended octane rating or different brands of gasoline until they find one that provides good performance.
The octane quality of gasoline is only a measure of its resistance to spark knock. The use of higher than recommended octane gasoline under normal operating conditions does NOT improve startability, idle quality, fuel economy, driveability, acceleration, engine durability, or emissions. In fact, most higher octane gasolines available in the U.S. have higher DI values than regular gasoline. Customers are most likely to experience poor driveability with premium gasoline than with regular.
Some vehicles, such as Viper, Prowler, 5.9L Grand Cherokee, 2.0L Turbo Talon, and 2.0L DOHC Neon have been specifically designed to take advantage of higher octane. These vehicles may have higher compression ratios, and/or more aggressive spark calibrations which provide optimum performance with the specified higher octane. However, other vehicles which are not specifically designed and calibrated to take advantage of higher octane will not benefit from higher octane.
Some vehicles may experience light spark knock in situations such as trailer towing or climbing steep sustained grades. Light knock or "ping" under these conditions is not harmful. However, if the customer is concerned about light knock under these circumstances, the use of 89 (R+M)/2 or even 91 (R+M)/2 premium gasoline may be temporarily warranted. If a vehicle is experiencing heavy spark knock on gasoline with its designed octane rating, this may be an indication of excessive combustion chamber deposits, or some other problem. Combustion chamber deposits can be removed with Mopar Combustion Chamber Conditioner p/n 04318001. Standard diagnostic procedures may help in identifying other potential causes of excessive knock.
Some gasoline marketers may advertise that their premium gasoline contains extra detergent additives. Under provisions of the Clean Air Act, ALL gasoline sold in the U.S. must contain effective deposit control additives. Nevertheless, if fuel injector or intake valve deposits are suspected of contributing to poor performance, occasional use of Mopar Fuel Injector Clean Up p/n 04549613 is a much less expensive way to maintain engine cleanliness than regular use of premium gasoline.
The attached charts (Figure 1 & Figure 2) show the negative effects of high DI fuel as related to customer satisfaction.
If fuel quality is suspected in causing a customers driveability concern, your zone technical office may be able to provide direction on procedures for fuel sample analysis.
POLICY: Information Only
post #4 of 14 Old 09-09-2007, 06:10 PM
Hybrid Booster
My Ride: 86 Daytona TurboZ
Images: 9
I have an 01 R/T and run regular all the time. The timing is automatically adjusted to compensate. Premium is recomended, but with the price these days it's been a long time since I used it.
rare_ram is offline
post #5 of 14 Old 09-09-2007, 08:23 PM
TD Hardcore User!
Engine: 2.5 turbo
Images: 20
You obiously know what your talking about but my brother and i have tested it with his subaru and my backup car 98 swift. we went from 87 to 89 to 91. My gas milage was quite better with 91 compared to 87. Same results with both the subaru and the swift.
post #6 of 14 Old 09-09-2007, 08:51 PM
Hybrid Booster
Images: 9
I know they say the HP rating (200) is based on premium fuel. I do think it is true that milage is better with premium but I have never tried to prove or disprove that. Is it enough to justify the price even if it is true? When I first got mine in Oct 2000, I went on a long trip and got 30 MPG on premium, driving on the highway at 85 MPH or was it 80, what ever 10 over is in Alabama. The window sticker said 29 Highway (5 speed).
rare_ram is offline
post #7 of 14 Old 09-09-2007, 09:03 PM
TD Hardcore User!
Engine: 2.5 turbo
Images: 20
I never put anything less then 94 in my baron.
post #8 of 14 Old 09-09-2007, 10:27 PM Thread Starter
heh, what octane is suggested by the owners manual? i got this car used, didn't come w/ one.
xenium is offline
post #9 of 14 Old 09-09-2007, 11:51 PM
Just A Guy
NAJ's Avatar
I just looked up your the fuel requirements in Dealer Connect for a 2003 Stratus Coupe w/3.0L and it will run on 87 octane but the use of premium fuel(91octane) is recommended. This should be on your fuel door.It will not allow me to cut and paste.
post #10 of 14 Old 09-10-2007, 10:17 AM
Hybrid Booster
Images: 9
check out 2gstratus(dot)org if your planning on doing any mods.
rare_ram is offline
post #11 of 14 Old 09-10-2007, 07:38 PM
My Ride: '85 Dodge 600 Ragtop
Engine: 2.2 T1
I've got an '01 Stratus R/T 3.0. I almost always run it on premium. A couple years ago I was on a trip and tried switching to regular to see if there was a big drop in gas mileage. There wasn't. I got 29-30 on the highway, no matter which fuel I used.
On the other hand, I think it runs a bit smoother at WOT, high-rpm on premium. There's not a big difference, though. I've never noticed any spark knock with the car regardless of fuel. Bill
Dodgeboy77 is offline
post #12 of 14 Old 09-10-2007, 11:47 PM
Hybrid Booster
Images: 9
Like I said before, that's because the puter automatically retards the spark to compensate for the lower octane. Making performance lower.
rare_ram is offline
post #13 of 14 Old 09-11-2007, 11:15 PM
Engine: 2.2 T1
<<Like I said before, that's because the puter automatically retards the spark to compensate for the lower octane. Making performance lower.>>
I realize that. That's why I was surprised that my gas mileage didn't go down when running regular. I figured that the ignition would retard, worsening the mileage.
Bill
post #14 of 14 Old 09-25-2007, 09:33 PM
My Ride: 1987 GT 5spd.Mustang
Bill
The computer will only retard the additional timing under load....it knows to or not via a knock sensor.....going down the highway there's no load on the engine (very little) so it's not going to reduce the timing enough to see poor mileage....But if someone did mpg testing with a car on a load-dyno or IDENTICAL take off conditions with different octanes of gas then you would most likely see the difference there.
Redturbotona is offline
Human Verification
