Old 02-10-2008, 10:06 AM   #1
leaky power steering pump
My Ride: 1989 Dodge Daytona
my cars power steering pump is going out or somethin i have to constantly put more fluid in it and it leaks pretty bad and its always whining....
its a 2.2 TII 89 daytona cs (originally had a 2.5) (shelby engine from an 87, dont no if that changes any, ive noticed i should include ALL info lol to get the help and advice i need....)
so is there an easy fix or does the whole thing need to be replaced???
daltondaytona is offline
Old 02-10-2008, 02:00 PM   #2
Re: leaky power steering pump
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
Feedback: (6)
Images: 3
If its not a line leaking then yeah probably best to just replace the whole pump.
impuresoul2k3 is offline
Old 02-10-2008, 04:20 PM   #3
Be careful, if it is a P/S hose and you keep running the fluid low(cause of the whine) the pump will be damaged.
Clean all the residual fluid from under the hood and look at the pump and lines while someone turns the wheel from stop to stop,this increases pressure and you should be able to locate the source of the leak. Check carefully around the crimps on the hoses.
Be sure you keep the fluid full and do not hold the wheel against the stops for more than a few seconds or pump damage will occur.
Advertising | Advertising | Mortgages | Myspace Codes | Valentine's Day Gifts
Page generated in 0.29485 seconds with 13 queries
