Old 05-01-2008, 07:23 AM   #76
Re: Top Speed & Fuel Economy
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
mmmmm 6 speeds
< makes Homer Simpson gurgling drooling noise
I dream of a good 6 speed tranny for FWD
ljbprrfmof is offline
Old 05-01-2008, 09:06 AM   #77
My Ride: '88 Shelby Z TII
They're out there, but the ones I'm talking about cost $$$$$. Not sure if I wanna go with a Quaife unit or try and get a good X-trac and have the bellhousing made. Of couse this is all WAY down the line, put in the "someday whaen I have money" file!
Reaper1 is offline
Old 05-07-2008, 09:26 AM   #78
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
I was following a guy driving my Shelby today, he was behaving, right up to the end, when he jumped on it from a stop sign. I got to drive through a nice little plume of black smoke. Is this car still running rich, or do I have another problem?
Just a reminder it is a CSX T with a Mopar Performance cal and we just put the stock size injectors back in the car.
Old 05-07-2008, 09:42 AM   #79
The Pope's Avatar
sounds more like a lack of ignition, the little puff is normal. Everyone should own a wideband sensor and run the engine with it. Then you get an adjustible fuel pressure regulator and then adjust fuel amounts under boost. your narrow sensor can be stuck in rich mode.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 05-08-2008, 06:12 PM   #80
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
Fuel Economy Report Time
Last tank full 21.41 miles per gallon That was a combination of my 5 mile commute, a couple of long errand runs through town plus one out into the sticks yesterday. Add in some WOT blasts, and I am pretty satisfied.
Next up, I found a chassis dyno 3 miles up the road. The guy turbocharges Mustangs (so they can keep up with turbo dodges ). $90.00 for three pulls. So I guess I am going to find out about my top speed and WHP.
Old 05-09-2008, 01:38 PM   #81
Well...you'll find out the gearind top speed, but not the true top speed of the vehicle. You can't simulate aerodynamic drag efficiently on a dyno that *I* know of. AFAIK it is still either a true driving test or a mathematical approximation based on known parameters....
Reaper1 is offline
Old 05-09-2008, 03:55 PM   #82
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
Yes that is true, wind and road drag will be lost factors here. But one factor gained is there will be no Penna State Police with radar guns in the building.
With my luck, I will end up with another blown head gasket.
Any advise on what maintenance I should perform before I hook it up and waste some gasoline?
Old 05-10-2008, 12:24 AM   #83
Same stuff you would do before drag racing it.
Reaper1 is offline
Mortgage | 0 Credit Cards | Mortgage | Secured Loans | Synchronization fast and easy
Page generated in 0.29524 seconds with 12 queries
