06-19-2008, 10:43 PM
#23
Re: 88 Shelby TII vacuum questions..
My Ride: 88 Daytona/07 9³ SC
Engine: 2.2TII/2.0T
Okay... so this thread was started about my car, but it seems that vacuum may not be the only issue.
Stored codes: 15, 34, 45.
15 - Vehicle speed sensor. Was advised that it will cause a stall on decel issue, which it has stalled three random times since buying the car about a month ago.
34 - Cruise servo. Cruise works great at times, but sometimes it will cancel out of the blue, other times it just won't work at all.
45 - Overboost shutoff. Have encountered the shutoff three times also, and usually under moderate acceleration, maybe ¼-½ throttle the car took off harder than I intended those times, also random.
Engine cooling fan runs constantly with the key in ON position. Check engine light has not been on at all with the engine running, but light works and comes on for initial check when turning the key to on before starting, and also produces codes when key cycled 3 times like it should. The only warning light that has illuminated was for low fuel, as was expected when it did (glad to know it works).
When cruising at a steady 70 mph on the hwy, vac/boost is usually around 0. A/C on in PANEL position will divert flow to floor & defrost if not reading less than -5.
Vac lines have been checked multiple times by multiple mechanically-inclined people, each feels they are routed properly and check-valves positioned to vac the proper way.
I've installed two "incorrect" vac restrictors from Advance in 2 of the 3 orifice locations (not the boost guage line) and it didn't seem to hurt not help the situation.
What suggestions or procedures should I follow from here to try isolating my problems? Could it be wiring/ground/vac solenoid related causing vac to purge when it shouldn't? I'm stumped.
