Old 06-11-2008, 09:42 PM   #1
Pulling block (heads already off)
My Ride: 1988 shelby z
Hey everyone i have a 2.2 liter turbo 2 dodge daytona shelby z. It has the a555 tranny and i am wanting to remove the block. How do i remove the block? Do i need to remove the tranny at the same time? if not then how long and what is the best way of doing this
bsbllfit7 is offline
Old 06-11-2008, 10:25 PM   #2
Re: Pulling block (heads already off)
u need a cherry picker. u can leave the tranny in the car but it's a pita. to remove block, take out all bolts holding it in, lift out, cuss and swear a bit and it'll come out
allmotor is offline
Old 06-11-2008, 10:30 PM   #3
My Ride: 95 Caravan
Support the transmission to avoid damaging the axles and mount. Pull the crank pulley off for some extra clearance.
turbo1168 is offline
Old 06-11-2008, 10:31 PM   #4
and another question, i see a mount on the backside of the engine against the firewall, is this a motor mount or a tranny mount?
Old 06-11-2008, 10:53 PM   #5
My Ride: 95 Caravan
It bolts to the transmission, it's a torque strut. Not all cars have them, but I believe all turbo cars do.
Old 06-11-2008, 10:53 PM   #6
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
personally i would pull both trans and engine. doesn't take much longer and imo it makes the job much easier
kermit is offline
Old 06-11-2008, 11:44 PM   #7
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX
Engine: 2.2(135) I4
Feedback: (33)
Images: 187
2 13mm bolts(pass. side mount), 3 18mm bolts(front mount~2-engine;1 transmission). around the transmission and starter, power steering, and that should be it.
Clayton ~ Forum Admin
--Design A TurboDodge.com Shirt contect, Click here--
1987 Shelby CSX #674
FWD Mopar Club of Oklahoma Forum!
moparfwdsleeper is offline
Old 06-11-2008, 11:44 PM   #8
My Ride: 87 CSX
Engine: 2.2(135) I4
Feedback: (33)
Images: 187
2 13mm bolts(pass. side mount), 3 18mm bolts(front mount~2-engine;1 transmission). around the transmission and starter, power steering, alternator, crank pulley and that should be it.
Old 06-11-2008, 11:59 PM   #9
Yeah... but now your into dropping the control arms to pull the 1/2 shafts, puking trans fluid all over etc. Better to pull all the bell housing bolts to the block, pull out the starter with all the wires still attached to it (harness unplugs over behind the battery), and find the one extra bolt at the back of the block below the starter. It's kinds hidden and will break the ear off the trans of you miss it and start prying the block away from the trans. Also pull the little tin cover at the bottom of the bell housing.
As was mentioned, support the trans so it basically stays in place. The block should slide away from the trans with a little persuasion. You will have to move it far enough to clear the trans input shaft out of the clutch assy.
IROCNOROLL is offline
Old 06-12-2008, 04:10 AM   #10
and is a cherry picker completely necessary to remove just the block?
Old 06-12-2008, 04:36 AM   #11
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
when I pulled my block, I left my trans in to avoid all the b.s. IROCNOROLL talked about.
It was the easiest freaking thing to do with a lift-plate for a V8. I put the lift-plate on a certain way and the motor was completely, I said completely, balanced. All I had to do was support the trans with a jack and slid the engine up and away. I expected some sort of struggle - but this was stupid-easy. I had to take a bunch of crap off the "front" of the motor 'cause it was in an L-Body - you may have more room.
Here are some pics of what I'm talking about the lift-plate and how balanced it was:
Good luck
Screamin4banger is offline
Old 06-12-2008, 08:39 AM   #12
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
I used a cheap-o "come-a-long"
the short block w/o trans or head weighs <200#
+1 on the balance point ; the batter balanced you have the motor, the easier the clutch spline will slide in&out ; can make the diff between PITA and not
detobias is offline
Old 06-12-2008, 04:05 PM   #13
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
You can do it the hill billy way with no hoist or picker. Just remove all the bolts from the engine that mount it to the tranny, remove the passenger and front motor mounts (with a jack under hte motor of course). then slide the engine away from the tranny. Jack up the car and remove the block from under the car. Block isn't that heavy like 100 lbs or so. Probably more awkward than heavy. I've done it twice and it worked. With one helper getting it back in wasn't too difficult either.
cawcislo is offline
Old 06-12-2008, 06:49 PM   #14
haha would it be wise to put a sled or something under the block so i can easily roll it out, IF i was going to do it the hillbilly way. I called star rentals a rental company by my house and its 25 dollars a day for a cherry picker. Im thinking about just doing that but then i wont know where to rap the chains, i would do the balance plate thing on the top of the block but i dont have any idea where to get one of those, if you even can. Is there an alternate way to use the chains from the cherry picker to pick the block up?
Old 06-12-2008, 07:05 PM   #15
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
Look just thread some shorter bolts in the head bolt holes at opposite corners of the block. Also look on your local bargain newspaper, people sell them cherry pickers for like $50 used. You will need it twice so it is the same price as renting minus having to hassle back and forth and worry about late fees.
dyno sheet
fmic install:
crazymadbastard is offline
Loans | Credit Cards | Manga | Mobile Phones | Ringtones
