Old 06-14-2008, 11:25 PM   #1
how to REALLY tune whole engine
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
1990 daytona es 2.5 turbo
hybrid T3/T4 (super 46 in S60 housing and stage 1 turbine in .63 housing)
stock swirl head
UNPORTED exhaust manifold
2.5" swingvalve
full 3" exhaust with no cat
dynoed at 250+ whp at 17psi
so how do I go about getting EVERYTHING set to the right value? specifically:
engine base timing
camshaft offset (adjustable cam sprocket installed)
fuel pressure (AFPR with +40's installed)
spark plug gap
computer timing/boost/injector maps (FWD stage 3 installed)
I have a wideband O2 installed, and a 1600F EGT gauge on runner #4.
All my modifications are in. I want to get this engine tuned for maximum drag racing performance. How do I do it?
I'm guessing:
some kind of reprogrammable computer
some dyno runs
But whats the right way to adjust the other things and in what order?
acannell is offline
Old 06-16-2008, 01:29 PM   #2
Re: how to REALLY tune whole engine
Feedback: (32)
engine base timing - 12 degree timing
camshaft offset (adjustable cam sprocket installed) - 0 degree
fuel pressure (AFPR with +40's installed) - Get a fuel calculator out and see what pressure is need for +40% and the stage 3 computer
spark plug gap - .030 - .035
computer timing/boost/injector maps (FWD stage 3 installed) - call FWD.
tryingbe is offline
Old 06-16-2008, 02:56 PM   #3
Engine: 2.5 Turbo 1
well THAT was easy now wasn't it?
stage 5 computer is enroute
so whats the point of an adjustable cam sprocket?
acannell is offline
Old 06-16-2008, 04:37 PM   #4
Feedback: (32)
If you have your head machined, your cam is going to be off a little. Or if you want to move your power band higher. Or if you use an aftermarket cam that is off center line...
tryingbe is offline
Old 06-16-2008, 07:01 PM   #5
My Ride: 88 Shadow
Feedback: (7)
Go to the dyno to test the cam timing. Move 2 degrees at a time, make 2 pulls each time to make sure it's consistant. Whatever makes the most power just set it to that.
moparzrule is offline
Old 06-16-2008, 07:41 PM   #6
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
advancing the cam shifts the power band lower in the rpm range, ratarding it shifts it higher in the rpm range.
if i were you id invest in some dyno time. find someone who has plenty of experience with 4cyl turbo cars, or better yet our cars. i wouldnt have blown my money on a stage 5 computer, would have been better off socketing the ecu and going with d cal- allows total fuel and ignition adjustability . someone who knows what they are doing will be able to wring every last ounce of power out of it with a setup like that.
crusty shadow is offline
Old 06-16-2008, 08:54 PM   #7
Engine: 2.5 Turbo 1
i agree with you. but the stage 5 was a free upgrade since i already had the stage 3. i am going to get things stable with stage 5 and then look into dcal or something else that allows total control, and then find an expert and dyno time.
acannell is offline
Old 06-17-2008, 10:07 AM   #8
on the adjustable cam sprocket- retarding the timing will almost always give you better 1/4 mile times. sure it feels slower because of having less power down low, but it more than makes up for it with more power up top. I run mine at 6-8 deg retard, and would run more if i could spin the engine faster to take advantage of it.
xrattiracer is offline
Old 06-17-2008, 10:56 AM   #9
Feedback: (32)
You already got the socketed ECU, now you just need chip and burner.
tryingbe is offline
Old 06-18-2008, 06:56 AM   #10
My Ride: 88 Shadow
Feedback: (7)
You got an EGT gauge? Because with that much retard I bet they are hot.
Old 06-18-2008, 09:12 AM   #11
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
Good question on can retard and egts, with ignition you are right about egts shooting up for sure. 8 degrees is a whole tooth on the cam right? One other way I heard to set the cam timing is to adjust it until you get the highest compression(psi).
dyno sheet
fmic install:
crazymadbastard is offline
Old 06-18-2008, 03:01 PM   #12
My Ride: 88 Shadow
Feedback: (7)
9 degree's is 1 tooth, but close enough.
Cam timing has just as much affect, if not more so, on EGT's than ignition timing!
Old 06-18-2008, 07:10 PM   #13
My Ride: '89 Daytona Shelby
You should start with fueling and getting that right. Changing the timing, either cam or ignition, shouldn't need a fueling change. You can use the EGT and your WB to see what the engine likes.
puppet is offline
Old 06-18-2008, 08:20 PM   #14
Engine: 2.5 Turbo 1
thats really not as simple as it sounds...first off:
1- this engine regularly exceeds 1600F (the max of my EGT gauge) at boost as low as 14psi with AFR's in the 11's.
2- the wideband says 11, the wideband says 12...whatever
how am I supposed to figure out what the engine likes? just guess how it feels when I floor it? its all so imprecise...plus things change run to run...
I mean I can set it to some arbitrary AFR, like "well everyone says mid 11's is good", so I adjust it to that. Then EGT's are 1700F. Should I care? Or not? Who knows?
acannell is offline
Old 06-18-2008, 08:47 PM   #15
My Ride: 88 Shadow
Feedback: (7)
Timing and fuel curves need to be in correlation. You can have it pig rich but still high EGT's due to timing retard. Sounds like your ignition and/or cam timing needs more advance. Most of the ignition timing will need to be changed in the calibration, unless you aren't at 12 degree's base timing already.
Books | Glitter Graphics | Mobile Phones | Mobile Phones | Credit Card Consolidation
Page generated in 0.42771 seconds with 13 queries
