06-23-2008, 10:51 PM
#16
Re: 4000RPM's = Brick Wall???
Well, some interesting and positive results. I removed my Grainger and returned to computer controlled boost. Yes, the car makes less boost and power, but the usable power band is MUCH nicer! Before, I was having trouble making any real boost in first and second gear. Then, just as I'd start really moving, I'd hit my 4500 RPM ceiling. Now, I build less overall boost, but I build it sooner and I'm able to wind it out to a higher RPM. I've taken it as high as 5000 RPMs and MOST of the time I have no problem. I do occasionally hit the ceiling, but for the most part the car is more drivable than it ever was with the grainger. Also, in relation to another question, I was mistaken, my vacuum at idle is right about 20 inches of mercury, not 15.
Any new suggestions in light of this new evidence? I still haven't been able to check fuel pressure as I lack the necessary tools at the moment.
Thanks!
-Walt
06-24-2008, 01:13 AM
#17
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Yep
Now you had a grainger, then went back to stock and everything seems fine, correct?
So that leads me to believe that you did not have an orifice between the grainger and the WG. Is this the case?
If you did have that right then its back to fuel or spark blow out IMO
06-25-2008, 07:35 PM
#19
My Ride: '89 Daytona Shelby
Fault codes?
06-29-2008, 11:37 PM
#25
My Ride: 87 shelby z daytona
Engine: 2.257L t2
hmmm keep the info coming, i have a very simular problem.. but mine i cant rev past 4-4.5k... sigh.
06-30-2008, 08:13 AM
#26
My Ride: '87 Daytona Shelby Z
Engine: 2.2l TII
turbodoctah have you checked ignition and cam timing, mine would max out around 4500, turns out my ignition timing was sitting at 0* BTDC to maybe 1* ATDC
06-30-2008, 02:55 PM
#27
Engine: 2.257L t2
07-04-2008, 12:35 AM
#29
Engine: 2.257L t2
hmmm i think imma replace my fuel filter.... its probably way past do anyways specialy since iv ran a couple tanks of E85.... its the only part i havent replaced.... litteraly.
