06-23-2008, 07:48 AM
3.0 ltr V6 - Bent Valve??
My Ride: 1990 Daytona es
Engine: v6
Hey guys
I'm just looking for any advise or info.......
What happened was the timing belt broke on my 90' Daytona. I have since replaced the water pump & Timing belt but she wont run right. She'll only run with the throttle open full & she makes a chuging sound. It feels like she is trying to push the exhaust back out through the Carb. I'm thinking I got value bent. Is this a common problem with the 3.0's when they bust a valve????
06-23-2008, 08:21 AM
Re: 3.0 ltr V6 - Bent Valve??
My Ride: Shelby Charger
Engine: 2.2 turbo II
Sound to me that you got your timing off. I never heard of a 3.0 bending the valves when the timing belt breaks
Check them out.
06-23-2008, 12:32 PM
Engine: v6
I've turn the engine over multiple times but the Timing marks are still dead on!!! & I never touched the Distributor........
06-23-2008, 01:22 PM
Engine: v6
I never touched the Plug wires, I only took the side off the engine to do the timing belt. The Car ran like a Top before she busted the belt. Is there a chance that she bent the valves? Or is it really unlikely for her to do that? I'm gonna have to do a compression test & C what that tells me........
06-23-2008, 01:37 PM
Engine: v6
OK - so if the marks are dead on, where do I start/ Should I leave the crank & move the Cam's??? What's the best way to do this????
06-23-2008, 01:53 PM
My Ride: 86 Laser XT
Engine: 2.2 turbo
Double, triple, and quadrouple check your timing. You got something wrong
If all you replaced was the timing belt and didn't do anything else then it has to be something to do with the timing.
06-23-2008, 02:52 PM
#12
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
You're certain your cam timing is good? Do the compression test you said you were gonna do. If you have piss-poor #'s all the way around- crank is off; if you just got piss-poor #'s on one bank - that cam is off; if you got bad #'s for one cylinder - maybe got a bad seat or dropped guide.
07-04-2008, 12:59 PM
#15
Engine: v6
I did a compression test & everything came back good, The Timing marks "seem" to be right on, Where to I go now?? How else do I check the timing, other than just the marks???
