06-24-2008, 11:09 AM
Re: need help! emissions
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
Yes, post #'s... but i will say NOx and combustion temps go hand in hand. Was this an idle test , loaded test, or IM240 test? Failing NOx at cruise - I'd check the EGR valve to make sure its moving freely (mityvac). There are a lot of hoses down there that get old and break, Be sure to check those. As a matter of fact, check all your vac lines. They used hard plastic harness that gets brittle and broken from age.
And like tryingbe said, plugs, wires, oil, filter, air filter, etc.... good start on any car
