Old 06-30-2008, 06:01 PM   #1
stripped crank pulley bolts, need advice for removal
My Ride: 1988 shelby z
hey everyone i recently stripped two of the bolts that hold the crank pulley in place, the other ones are already removed and im trying to get to the cap that goes over the main bearing cap bolts, any advice on removing these stripped bolts would be great
fyi i tried using an 8mm stripped bolt remover (grips into the bolt as you try to loosen it) and it didnt work and now spins freely as well
bsbllfit7 is offline
Old 06-30-2008, 06:21 PM   #2
Re: stripped crank pulley bolts, need advice for removal
unclear on ur desc? u rounded the head of the bolt or did u strip the threads? cuz when the threads are gone, that a stripped bolt, when the socket or wrench cant grab the bolt then the head is rounded and not stripped? so whatcha got?
allmotor is offline
Old 06-30-2008, 07:06 PM   #3
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
you will have to dremel / grind off the head of the offending bolt(s)
then after you remove the pulley, hopefully there is enough stub sticking out to get a vice-grip on
detobias is offline
Old 06-30-2008, 07:25 PM   #4
what kind of dremel bit will be needed and yes the heads are rounded
Old 06-30-2008, 08:54 PM   #5
My Ride: 95 Caravan
IIRC, the 2.2 uses a reverse torx type bolt head. I don't have a 2.2 here to look at, but if that is the case, you are using the wrong type socket. Look at your other bolts to see what the head looks like. Torx head has 6 points, where as a regular bolt has 6 flat sides, like a 6 sided stop sign. Get the right tool and most likely you will be able to remove the 2 bolts. If not, I have had some success with using a cutoff tool, to cut a slot in the bolt head for a flat blade screwdriver. Before cutting the slot, beat the bolt head a few times with a drift and a BFH (Big F'in Hammer) to loosen it.
turbo1168 is offline
Old 06-30-2008, 09:53 PM   #6
problem fixed, i used a dremel and cut off the bolt head and used a pry bar to break the remainder of the bolt head off
Old 06-30-2008, 10:23 PM   #7
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
Ah... thats the easy way.
Wanna know the hard way? leave just the bad bolt in over winter. The freeze/thaw cycles of the water that gets behind the pulley will snap them of after a while..lol
Shoots that crank pulley 2 blocks down the street at the top of first...lol
Screamin4banger is offline
Old 07-03-2008, 10:41 AM   #8
For future reference my personal favorite is welding another bolt on the rounded head if you have access to a mig welder. The tricky part is making a good weld but I've removed those same bolts by welding.
86daytonaZ is offline
Old 07-03-2008, 11:34 AM   #9
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
It's a little easier to tap a 5/16" I.D. nut onto the head of the offending bolt, and weld the inside of the nut to the bolt head. The heat from welding, and a socket on the nut makes the bolt come out easy as pie.
ol"blue is offline
Old 07-03-2008, 10:02 PM   #10
Also excellent for broken studs.
Old 07-03-2008, 10:11 PM   #11
My Ride: omni glh
did mine with hammer and center punch, couple good hits at an angle to remove and they come loose
fochtup1 is offline
Credit Card | Mortgages | Mortgages | Credit Counseling | Refinance
Page generated in 0.42534 seconds with 13 queries
