Old 07-05-2008, 01:38 PM   #1
How did I break a headbolt?
I am so mad right now. This shadow i bought with a messed head was just putting the head on and one of the bolts would not torque to 65 ft lbs and i guess i turned too much trying to get it there that the bolt just snapped. Now this car is garbage because i cant do a motor and i cant pull it out as I need to move at and of month and don't know of il even have a drive way there. How did this happen what did I do. They were brand new MP headbolts. It was one of the end bolts on driver side. It just kept turning and would not hit 65 ft lbs even though all the others did. it didnt even seem to get harder to turn before it broke like it did right before the other bolts hit 65
88lebaron is offline
Old 07-05-2008, 01:49 PM   #2
Re: How did I break a headbolt?
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
did you clean out the bolt hole?maybe there was water or oil in the hole. remove the head again take the bolt out and inspect the hole.
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
crazymadbastard is offline
Old 07-05-2008, 02:08 PM   #3
Feedback: (33)
Engine swap is 2 days... with a friend.
tryingbe is offline
Old 07-05-2008, 02:29 PM   #4
so u just pull the head, extract the broke bolt, clean out the holes, put in some new bolts and properly torque it. bfd!
allmotor is offline
Old 07-05-2008, 03:18 PM   #5
And how do i go about getting bolt out
Old 07-05-2008, 03:31 PM   #6
golly, that can be really ez, how good is ur prob solving skills?
lets see a pic of how bad u screwed up?
ever heard of an ez-out?
allmotor is offline
Old 07-05-2008, 04:09 PM   #7
hotrodguru
dirtyglhturbo's Avatar
My Ride: 86 glh turbo
Engine: t2 2.2l intercooled
as long as you didnt cross thread it or anything bad, you prolly could just back it out w/ some vise grips. hopefully it didnt break flush with the block.
dirtyglhturbo is offline
Old 07-05-2008, 04:27 PM   #8
Garrett Booster
My Ride: 87 daytona shelby z
Engine: 2.2L Turbo II
where did the bolt break? near the top or at the thread end. The longer the remaining portion of bolt is still in there the easier it will be to remove. either way pull the head off see what kind of mess you have. Might be worth the the effort to chase the threads with a tap to clean them up so that you don't have another oh s@#t moment.
mark joseph is offline
Old 07-05-2008, 08:19 PM   #9
Feedback: (33)
Double nut the "stud" aka former head bolt, Vise grip, weld a nut to it, whatever.
tryingbe is offline
Old 07-06-2008, 12:00 PM   #10
It broke at the top of the threads so im assuming it is inside the block but I will pull head to see. And I have heard of easy outs but know nothing about how to use or even what they look like lol. il research that
Old 07-06-2008, 01:39 PM   #11
My Ride: 99 Cummins
Engine: 5.9
Images: 6
Sell your car, buy a new hyundai.
Timmay2 is offline
Old 07-06-2008, 02:29 PM   #12
hotrodguru
^ must be a hyundai salesman
Old 07-06-2008, 02:35 PM   #13
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
Well thats dumb.
Go from a car thats 20 years old and is in a little need of some help to a car in a year or two will need more then a little work and its more expensive to boot.
GREAT ADVICE
1986 Laser xt t1 5 speed sunroof-new purchase
89 Lebaron GTC Convertible t1 auto- BUY IT PLEASE
Need a set of wagon wheels???- http://www.turbododge.com/forums/f7/...on-wheels.html
Old 07-06-2008, 02:46 PM   #14
Originally Posted by turbokid View Post
Well thats dumb.
GREAT ADVICE
so where's you advice? if u aint got nothing to contribute u throw ur $.02 in?
allmotor is offline
Old 07-06-2008, 02:52 PM   #15
Engine: 2.2 turbo
Images: 2
My advice is dont buy a hyndai!
can that not be infered from my post
The car doesn't need a new motor you merely gotta get yourself an easy out and get that sucker back out!
Go get yourself some new headbolts from the parts store.
I kinda figure your using the originals because you asked where you could get another head bolt!
Q
(theres my advice trouble maker )
