Old 04-18-2003, 05:25 PM   #1
Compression ratio?
Honda_stomper
If I use lower compession pistons, but keep the stock length rods and bore, will the displacement change?
Or does displacement only change if I change the length of the rods or bore the cylinders?
Thanks
D
Old 04-18-2003, 10:23 PM   #2
Garrett Booster
Lower compression pistons do not change displacement nor does the length of the connecting rod.
The bore size affects displacement as does the crankshaft stroke.
The connecting rods just "connect" the pistons to the crank.
Thanks
Randy
Glhs60 is offline
Page generated in 0.12073 seconds with 11 queries
