Old 07-20-2008, 03:30 AM   #16
Re: Air only blows through floor! Whats wrong?!?!
My Ride: 86' Daytona Turbo Z
Engine: 2.2 TI
Images: 32
Originally Posted by mmtphoto View Post
windshield PISSER LINE-LOL!!!! Gotta admit, there is some good stuff on here...
Ya like that reference huh... I had the same reaction when I heard my boss use it. Now I say it among many other things he's said whenever possible. The one he said that really busted my nut was "Come hold this chicken while I F**k it." It was one of those hold this socket while I hit it with a hammer things. That one had me in stiches.
woodrow Z is offline
Old 07-30-2008, 10:10 PM   #17
My Ride: 1988 shelby z
so i took out the air control unit from inside the car today and took a look at it. I have no idea what im supposed to be looking for. I pressed all the buttons like floor defrost etc. . . but didnt see anything wrong. Where am i supposed to be looking, and also i didnt find a vac source anywhere on this thing so am i looking at the wrong thing?
bsbllfit7 is offline
Old 07-30-2008, 10:45 PM   #18
My Ride: shelby z
If you didn't find a vacuum source on the controller, that is the problem-it has to have vacuum to open and close the various doors to direct airflow-NAJ posted a diagram earlier in the thread, if the unit is out, I'd make a print of it and look carefully at it-has to be there somewhere.
mmtphoto is offline
Old 07-30-2008, 11:18 PM   #19
it doesnt even look like there is a place for the vac to be on this unit. There are wires that were almost directly inline on the back of the unit, with the different button selectors. Ill try and get a picture of later tonight
Old 07-31-2008, 05:34 PM   #20
here are the pictures sorry for the camera phone quality but its all ive got right now, see what im talking about there arent any connectors for a vac hose or anything
Old 07-31-2008, 05:45 PM   #21
The vacuum port must have broken off and is lying in the dash with the vacuum harness still connected.
There are only 2 types of climate control.
ATC which uses electric motors for the mode/blend doors
Manual HVAC which uses vacuum operated mode doors. The eletrical connector is for the blower switch and the cable is for blend door temp control.
Old 07-31-2008, 06:17 PM   #22
there are two electrical plugins that were on this thing, one looked like it was for the mode doors and the other for the motor which tells it how much air to blow. I can post pictures of the two harnesses if that would help as well
Old 07-31-2008, 06:32 PM   #23
That is the same control unit that is in my car, the other connector is for A/C on/off.
Here is a pic of the wiring for your control unit.
Old 07-31-2008, 07:15 PM   #24
so where exactly is the vac source supposed to be at on the control unit?
Old 07-31-2008, 08:33 PM   #25
I cannot locate a pic but it should be right on the back, there will be 6-7 vacuum ports, the vacuum harness has all of those lines that run to a molded connector that would plug into the vacuum ports on the back of the unit.
The main vacuum line from under the hood should enter the interior by the heater hoses and comes from the brake booster.
Old 07-31-2008, 08:48 PM   #26
i can see where it comes throught the firewall, and yes is right off of the brake booster. Now i dont have a clue where it comes in through the firewall at
Old 07-31-2008, 09:19 PM   #27
You should be able to find the vacuum harness, like I said there are 5-7 vacuum lines all together, it is probably lying behind the dash, if the radio is under the control head like mine remove it to give yourself more access.
Old 07-31-2008, 09:49 PM   #28
everything is removed from that center dash area and there are no vac lines to be found anywhere. How come there is a total of like 15 wires between the two harnesses for this thing. Im just not so sure mine operates off of vac
Old 07-31-2008, 09:55 PM   #29
Take a look at the heater box and look at the motors on the box, do they have vacuum ports or electrical connectors. The only electrical you should see is to the blower resistor and blower motor.
How long have you had this car?
Old 07-31-2008, 10:00 PM   #30
ive had the car for awhile but shortly after getting it the engine crapped out, ive probably had the car for a year and a half but it ran for only about the first 4 or 5 months. I am purchasing an engine to throw in it and hope to have it ready by the end of the summer. So in the mean time im trying to figure out all the little things which there arent too many of, idk if its a good thing or a bad thing that all the problems are pretty bad haha. Well anyway ill go take a look right now, the heater box is on the backside of where the stereo and control unit are correct?
Proxy | Property in Spain | Remortgaging | Home Loan | Mortgage
Page generated in 0.47161 seconds with 14 queries
