Old 07-06-2008, 05:20 PM   #1
Air only blows through floor! Whats wrong?!?!
My Ride: 1988 shelby z
Hey everyone when my daytona was still driving i had a pretty annoying problem with the heater/fan controls. Whenever i tried to get it to blow air through the panel or defrost all it would do is come through the floor! Now this is extremely annoying and id like to figure out what is causing it to only blow through the floor. Any help is greatly appreciated
bsbllfit7 is offline
Old 07-06-2008, 06:10 PM   #2
Re: Air only blows through floor! Whats wrong?!?!
My Ride: 91 lebaron, 04 ninja
Engine: 181ci v6
Images: 1
you might have to take the blower motor out but the door that controls were the air blows is either stuck or the arm is broke it might be on the top of the houseing
thejoker1290 is offline
Old 07-06-2008, 07:05 PM   #3
My Ride: 92.sdw.64.300.90.spt
Engine: 2.5 and 440
this is a easy one check the tiny plastic line coming from the brake booster it will be heading toward your interior sometimes they crack or the critters bite them any hole in this plastic line and the vents will not work .
mrglenn is offline
Old 07-06-2008, 08:17 PM   #4
If it was a vacuum supply problem from under the hood air flow would be from defrost only, defrost is the default position.
+1 on mode door sticking or broken, check that the control unit is actually changing position and supplying vacuum to the other motors.If vacuum stays constant on the floor motor regardless of position chosen the control unit is at fault.
Old 07-06-2008, 10:11 PM   #5
My Ride: 89 Daytona Shelby
Engine: 2.2l Turbo II
Maybe u need to replace the floor pan!?! just kidding, i dont do much posting on the forum but i find that it is a great place to find information when i am working on the daytona.
mondo1982 is online now
Old 07-06-2008, 10:38 PM   #6
My Ride: 86' Daytona Turbo Z
Engine: 2.2 TI
Images: 24
Glad I came across this thread. Just 2 days ago I turned the A/C on in my 86 Daytona Z. It has stopped blowing out the pannel. It only comes out the defrost and the floor. Its annoying. My legs get really cold though. And I discovered that whenever I hammer it down my A/C gets warm. I found out that my water valve under the hood has stopped working. Its still letting hot coolant flow through the heater core. So its not shutting off. I zip tied the valve in the closed possition because I don't exactly need it in 100 deg weather. Could these be associating issues with a broken vacuum line?
woodrow Z is offline
Old 07-07-2008, 03:39 AM   #7
how does someone go about checking the mode door? And im not sure if its coming from defrost as well because it did thaw out the windows when it was cold in the winter. Ill take a look at the vacuum tomorrow and will hopefully find something, is the vacuum line the very very thin line that is going to the firewall?
Old 07-07-2008, 04:51 AM   #8
The vacuum line that goes thru the firewall is the main vacuum to the control unit, there is also a vacuum harness on the control unit that supplies vacuum to the mode door motors on the heater box.
Locate the vacuum motor for floor on the heater box and disconnect the motor from the mode door and see if the door moves. You will not see the door itself, that is inside of the heater box.
Old 07-11-2008, 06:01 PM   #9
Engine: 2.2 TI
Images: 24
Found my leak! it was about 4 inches from the line that goes into the brake booster. Right where it bends. Go figure right.... Repaired with a piece of windsheild pisser line. Now it blows in my face!
Bsbllfit7.... did you ever find your problem?
Old 07-11-2008, 07:04 PM   #10
My Ride: shelby z
windshield PISSER LINE-LOL!!!! Gotta admit, there is some good stuff on here...
mmtphoto is offline
Old 07-12-2008, 12:05 AM   #11
nope havent began to look yet ive been trying to fix other problems with the car but i will look into it soon. Does anyone have a tutorial on how to get to these motors and vents?
Old 07-12-2008, 02:00 AM   #12
Engine: 2.5 and 440
told you so I had the same problem sometimes things are simple
mrglenn is offline
Old 07-12-2008, 06:37 AM   #13
Vacuum source in and out is behind the control unit. A vacuum harness plugs into the rear.
If your problem is related to the vacuum motors you should be able to access them from under the dash or thru the glovebox opening.
If the problem is with a mode/blend door the heater box will have to be removed.
Old 07-12-2008, 01:36 PM   #14
ill check the vacuum stuff today and if i dont see anything wrong i might need some help on finding out exactly how to get to the heater box
Old 07-12-2008, 01:39 PM   #15
I think you will find a vacuum problem under the hood, seems to be the common problem.
Mortgages | Car Insurance | Debt Consolidation | Bad Credit Mortgages | Personal Loan
