Old 07-06-2008, 06:57 PM   #1
hard to start when engine warmed
My Ride: shadow
1987 shadow turbo. stock.. 38000 original miles (yup thats right 38k) little old lady car! did all the regular things, cap, rotor , wires,plugs, filters, fluids to get her ready to roll, just one problem, starts great cold, hard to start, cranks excessively have to pump the accelerator sometimes to get her to start when warm, then blows some black smoke upon starting and seems to run fine then...
gtpskip is offline
Old 07-06-2008, 09:54 PM   #2
Re: hard to start when engine warmed
My Ride: daytona shelby z
Engine: 2.5 TI
My 2.5 TI daytona do the same thing I need to hit the gas to make it start and a small black cloud go out of the muffler. This is not very dangerous or the car. I do this since I own the car ( it makes 1 year now)
carzboyz is offline
Old 07-06-2008, 10:13 PM   #3
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
"pumping" the accelerator does nothing for you, Its not a carb Now holding it to the floor turns off the injectors and that can help.
do you have any codes? It sounds like the computer thinks the engine is cold when it is not..
Screamin4banger is offline
Old 07-06-2008, 11:01 PM   #4
Check basics.
Fuel Pressure, Static, Running Cold and wait until engine gets warm does pressure drop?
What is Fuel Pressure while cranking warm?
Is the Throttle Body and AIS clean of Carbon?
Are there any Vacuum Leaks? Is Vacuum to the Baro Solenoid/Map Sensor ok?
Are there any fault codes present?
Old 07-10-2008, 10:27 PM   #5
My Ride: shadow
[quote=Screamin4banger;1315286]"pumping" the accelerator does nothing for you, Its not a carb Now holding it to the floor turns off the injectors and that can help.
thanks for that
I am just reporting the conditions in which the car reacts ... and in this case holding the accel does nothing to help with the starting condition
gtpskip is offline
Old 07-10-2008, 10:29 PM   #6
My Ride: shadow
fuel pressures.. check
cleaned throttle body and assys when replaced ignition
no vacuum leaks during smoke test
no fault codes present
that is why I am asking
gtpskip is offline
Old 07-10-2008, 11:01 PM   #7
My Ride: shadow
Tried A New Map Sensor On Advice Of Tech Where I Work..problem Solved
gtpskip is offline
Mortgage | Massage Classes | Myspace Layouts | Mobile Phones | Loans
Page generated in 0.29466 seconds with 13 queries
