Old 07-20-2008, 06:30 PM   #1
Repair oil feed line
Hi, When i was removing head to I made mistake of cutting oil feed line (rubber part) in half and was wondering if there was any safe way to fix that or will the oil pressure blow off anything i put in there.
88lebaron is offline
Old 07-20-2008, 06:35 PM   #2
Re: Repair oil feed line
My Ride: 88 c1500 Lowrider
Engine: 305
Feedback: (7)
any clamp & hose worth holding hmmmm say 65Psi of Oil pressure would be Okay IMO , Lets see what the rest of TD.com has to say
shadetreeshop is offline
Old 07-20-2008, 07:10 PM   #3
Feedback: (33)
Replace the line.
tryingbe is offline
Old 07-20-2008, 07:12 PM   #4
Engine: 305
Feedback: (7)
Man Your everywhere Tringbe.
Old 07-20-2008, 07:35 PM   #5
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
if you have say 2in at least on both sides of the cut, you could try a brass tube between and strong clamps to mend your indescretion
xtrempickup is offline
Old 07-20-2008, 07:55 PM   #6
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
Get a new one - they are not expensive
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
Screamin4banger is offline
Old 07-20-2008, 08:17 PM   #7
My Ride: SOLD!
Don't chance a 710 leak, it could cause a fire. Replace it.
Gutfeeling is offline
Old 07-20-2008, 11:11 PM   #8
How much does the oil line usualy cost from dealer?
Old 07-21-2008, 12:19 AM   #9
My Ride: 87 GLHS
Just get the braided steel version from one of our venders. It is better than the original and cheaper.
rfb6435 is offline
Old 07-21-2008, 01:30 PM   #10
My Ride: 86 Daytona TurboZ CS
I doubt you can get one from the stealer anymore. If so, they would be very expensive (as always).
If you got the cash, get the braided steel.
If not, pull one at the junk yard.
I've also seen the home repair (aka. new piece of reinforced rubber hose held in place with worm gears) run for thousands of miles.
chilort is offline
Old 07-21-2008, 01:39 PM   #11
I wouldn't waste the time on a junkyard one... Too much fooling around and then who knows what crud is in there. I think you did yourself a favor by cutting that line. Go get a new one from one of our vendors.
My Mopars:
Old 07-21-2008, 05:29 PM   #12
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
Just clamp on a braided hose.i use hose clamps on two of mine run for over 100k.Makes it easier to pull turbo also.I use short section of AC hose for the water line also.
4Daytonas is offline
Old 07-21-2008, 05:46 PM   #13
Feedback: (33)
And if you have a leak and you have a manual transmission, you can kiss that clutch good bye.
tryingbe is offline
Old 07-21-2008, 05:54 PM   #14
If its a matter of being a cheap TD'er...
If you go on eBay there's a guy in Windsor ON selling braided oil lines for like $24 shipped anywhere in US or CA.
Thats about as reasonable price as you're gonna find.
My Mopars:
Old 07-21-2008, 07:30 PM   #15
My Ride: 85 Shelby Charger
Engine: 2.2 T-II
I fixed one before with a piece of tubing and a compression fitting. I replaced the complete forward hardline and the rubber hose. Never had a leak and looked good too.
tmef is offline
Vegas Hotel | Credit Card Consolidation | Adverse Credit Remortgage | Western Union Money Order | Remortgages
