Old 07-25-2008, 02:23 AM   #1
Angry The small things always go wrong
My Ride: 89' Chrysler Lebaron
Engine: 2.5L T1
Well I finally had the motor running today perfectly. And I was changing the thermostat over to a 180 degree. So after im done i go to move the dipstick tube back into place and the ****ing thing breaks clean off. I dont know if it broke off or it just came out. Is it supposed to come out? or did my dumbass break it. How do i fix it so oil stops spurting out? Always the small **** that goes wrong. Always.
-Hagenator
Hagenator is offline
Old 07-25-2008, 05:58 AM   #2
Re: The small things always go wrong
Same thing happened to me when I removed the head back in Febuary.
I found a plug to put in the hole temporarily and ordered a new dipstick tube from Mopar.
Surprisingly it was still available.
Old 07-25-2008, 02:17 PM   #3
Engine: 2.5L T1
Yeah ill put a plug in. Do I have to pull the oil pan to get to the bottom of the dipstick when I get the new one? Is it held in by a bolt or something?
Old 07-25-2008, 02:42 PM   #4
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
It is held on by friction. so maybe you can put a large wood screw in and pull it out. or maybe there is a bit you can grab with a plier.
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-25-2008, 03:16 PM   #5
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
our dipstick tubes wiggle out and even full of oil i dont think it will leak out after pulling...though most of them tend to break off and leaves you with more of a problem. Soak it with some wd-40 or equivilant and take some pliers and try turning it down by the base...
I've also fished some broken ones out with a pocket/telescoping magnet
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is online now
Old 07-25-2008, 03:46 PM   #6
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
i broke off one in the red convertible and I ended up having to pull the pan and tap it out from the bottom. Not a huge deal. I also have a lift to work on the cars with when its empty so thats always nice.
Q
Old 07-25-2008, 04:51 PM   #7
Garrett Booster
My Ride: 86' Laser XT
Engine: 2.2L Turbo I>II
Try a screw extractor!
pooty is offline
Old 07-25-2008, 05:43 PM   #8
The only bolts are at the block and t-stat housing, we were able to remove the broken section from up top with a lot of patience.
If worse comes to worse before dropping the pan drain the oil and punch it thru and try to grab it with a magnetic pickup tool thru the drain plug opening.
Old 07-25-2008, 06:35 PM   #9
My Ride: shelby z
Very clever and creative!-Nice! Removing the oil pan is not a big deal, but I like this alternative-worth a try.
mmtphoto is offline
Old 07-26-2008, 12:49 AM   #10
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
wow, you guys make this sound easy.
I got a block on an engine stand and cant the dipstick tube out for the life of me. It's not broken - I just need it out! I've tried pounding it out from the bottom with various punches and chisels only to mushrooming the bottom of the tube. I even have a slide-hammer that screws into a vice-grips and cant get it from above either.
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
Screamin4banger is offline
Old 07-26-2008, 05:44 AM   #11
Everything online or in the service manual "sounds" easy but we all know it is not.
Kind of like where the service manual instructions for starter replacement on the
2.2/2.5L turbo says...
disconnect - batt cable, remove electrical connectors, remove mounting bolts, remove starter, YEA RIGHT!!!
Funny thing is that I expected the new dipstick to be a tight fit that I would have to fight with to go all the way down and it fell right in and all I could think is "thats it?, something must be wrong."
Old 07-26-2008, 06:23 AM   #12
My Ride: shelby z
'easy' is a relative term-recently did the starter on my turbo II, NOT easy IMO-I have removed the oil pan a couple of times, that is an easy job on these cars, there's lots of room.
mmtphoto is offline
Old 07-28-2008, 07:44 PM   #13
Engine: 2.5L T1
Thanks alot guys for the help. I'm ganna do it soon once i get around to it.
Old 07-28-2008, 09:25 PM   #14
My Ride: '89 Dodge Shadow
Engine: 2.2L TBI
Images: 2
I haven't ever had a broken tube, but I've had a couple pop out of the hole. I simply put a little Form-a-Gasket Black on the roll and stab it back in the block.
Lone Eagle is offline
Credit Card Consolidation | Bad Credit Mortgages | Rewards credit card | Remortgages | Upvc Doors
Page generated in 0.50032 seconds with 13 queries
