Old 08-05-2008, 02:12 PM   #1
ignition timing marks
My Ride: 91 Daytona Shelby
Engine: 2.5l
Images: 2
i am trying to set the ignition timing on my 2.5 turbo but i can't read the marks on the bell housing to determine what the lines mean. the tag says it needs to be at 12 degrees and it wasn't even in the window. if someone could tell me what the marks me that would be awsome.
thanks
Diablo is offline
Old 08-05-2008, 02:20 PM   #2
Re: ignition timing marks
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
go get a little wire brush and some brake cleaner so you can see what you're doing.
and you disco'd the CTS? if not, the mark will move around as you try to set timing... that could be why it never showed up in the window.
Click Here: I need a 2DR L-Body REAR Bumper Mount
My Mopars:
85 Shelby Charger - Garnet Red/Silver <- 100% Rust-free - Beautiful one day
86 Shelby Charger - Black/Silver <- $150 Rust-bucket Beater
73 Charger SE - Gold/White top <- Rust-free - will be MS & TT eventually
91 Spirit R/T - White <- Sacrifice to the L-Body Gods
Screamin4banger is offline
Old 08-05-2008, 02:21 PM   #3
Engine: 2.5l
Images: 2
i cleaned it up i just cant read the casting numbers on there. at least i think they are numbers.
Diablo is offline
Old 08-05-2008, 02:41 PM   #4
yes they are numbers... I dunno if the marks in the windows are all the same. I think 12 is gonna be the second to the last line toward the firewall.
My Mopars:
Old 08-05-2008, 02:51 PM   #5
Engine: 2.5l
Images: 2
the timing must have been way off cause i put it on the 2nd from the firewall and its like driving a different car! not sluggish at all anymore.
thanks screamin4banger
Diablo is offline
Old 08-05-2008, 04:53 PM   #6
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
to make it easier to see you can just spray it with black spray paint, then go back and wipe off the #'s- aluminum over black background- hard as hell to miss
crusty shadow is offline
Old 09-07-2008, 01:46 AM   #7
My Ride: 91 shelby daytona
I had this same issue, Doesn't look lke mine are numbered at all. Just lines. I took a guess.. Theres only 8 marks right? In any case i just guessed the first was 0 and went from there (that turbo oil feed line right above was leaking which caused the hard time seeing it)
Powell is offline
Buy PSP | Send Money Online | Loans | Loans | Loans
Page generated in 0.32494 seconds with 13 queries
