View Poll Results: 2.5 16v Hybrid or 2.4 swap?
2.5 16v Hybrid 5 29.41%
2.4 swap 12 70.59%
Voters: 17. You may not vote on this poll
Old 08-22-2008, 02:02 AM   #1
2.5 Hybrid or 2.4 swap?
My Ride: '87 Turismo
Engine: 2.2 sohc
I've been torturing myself over which path to go: 2.5 with a 16v hybrid head or a complete 2.4 swap . It would be going into a '90 Turismo (Plymouth version of Charger) that currently has a 2.2 non turbo automatic. I've had a 2.5 turbo out of a LeBaron scattered in parts for a while now. If I was to build to the 2.5, I would use the Mikuni setup I have. I also have shorter gears for the transmission already. It would be primarily used as a bracket car. Which would be more cost effective? Which would be easier? Please help!
frankenstein01 is offline
Old 08-22-2008, 03:22 AM   #2
Re: 2.5 Hybrid or 2.4 swap?
My Ride: 1993 Daytona
Engine: 2.5L MPI N/A
Images: 1
I'm going with a 2.4L swap so I can still have A/C and find parts for it easier. Not to mention its easier and less expensive.
ZoskalonMPI is offline
Old 08-25-2008, 02:41 PM   #3
Engine: 2.2 sohc
Could you guys that voted give some insight as to why you chose what you did? Thanks!
Old 08-25-2008, 03:07 PM   #4
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
From someone that's done both, you'll be happier in the end with the 2.4. You pretty much only need to fabricate one mount. Since you're NA, you can just use a bolt for the passenger's side mount with a PT or SRT engine mount. You can then either make a front mount or adapt the newer torque bar on the bottom to the K-frame.
90TurboVan is offline
Old 08-25-2008, 04:20 PM   #5
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
I would rather fab a motor mount than all the other plugging and modifying to the block to get a hybrid running. Also, having a newer motor seems the way to go.
dyno sheet
fmic install:
crazymadbastard is offline
Old 08-25-2008, 05:07 PM   #6
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
The 2.4 motor is just nicer designed, easier to work on, parts are readily available(and will be for years to come). If something breaks, you dont have to redo all the custom plumbing, just get a motor and swap
speeduphoria is offline
Old 08-25-2008, 08:14 PM   #7
My Ride: 85 laser
Feedback: (7)
2.4 Is much easier to do not sure about it being a better engine though
jim34 is offline
Old 08-25-2008, 11:11 PM   #8
My Ride: 84 Plymouth Turismo
Engine: 89 2.5 I/C TURBO
They never made a 90 Turismo... The Charger and Turismo 2 dr cars stopped production@Belveder assembly in 87.. The Omni and Horizon 4 dr versions went until 1990 and they were TBI...
TurboTurismo is offline
Old 08-26-2008, 03:34 AM   #9
Engine: 2.2 sohc
Ohh man, I must've been thinking of the Mustang. Oops... Yeah, it's an '87. A big thank you to all that commented back re-assuring my thoughts. I'm probably going to pick up an Srt-4 motor with the stock electronics. Wish me luck!
Web Master | Power Rangers | Free Advertising | Online Advertising | Keeping Aquarium Fish
Page generated in 0.35200 seconds with 14 queries
