08-27-2008, 09:04 PM
new engine noise =\
My Ride: 91 shelby daytona
Wondering if anyone would want to take some educated or non educated... guesses as to what this may be..... First noise i know i've heard before but sounds along the lines almost like the rockers or something are slapping really hard or maybe another way to describe is while driving in the lower rpms i would say is when i hear it more and it clanks slightly. Wierd thing is it doesn't always do it, and seems to do it more like if i'm going up a hill. I wondered if it was my clutch or maybe something with a rod? When it happens i can feel the clutch vibrate a bit.
Another note, i'm guessing this developed from my injector harness having issues (occasionally check engine light for #3 injector not firing) but i know my clutch is having issues due to a bad clutch cable. I checked compression and thats still good all through, spark plugs had a little white on them but didn't look bad, timing is dead on (i just replaced timing belt cause i thought maybe it jumped a tooth and looked like it may have, there was also oil deposits on timing belt due to oil pan leak) but it seems to idle ok. I'm not 100% sure if it did this before since i just threw on a muffler and now i can actually hear the motor.
Ok there is another slight noise, after changing the timing belt, i'm getting a minor rattle from one of the pulleys. I checked them all though and all bolts are tight. i pulled off the a/c belt and noise seemed to have reduced . Sounds like an occasional metal clanky. like it's nicking something . Guess i should of checked to make sure the alternator blade isn't hitting anything...
