Old 08-28-2008, 12:30 AM   #1
89 turbo mini with ac delete bracket. wat belt do i use?
My Ride: SRT-4, Turbo Mini
Engine: 2.4, 2.5
I have an 89 turbo mini that had the ac compressor removed so i installed the alternator bracket from a non ac vehicle. So what belt do i use and is it right that there is no tensioner just the adjustment i make with the alternator? again the belt only goes on the crank pulley and alternator and of course that belt drives the waterpump. I had a belt on there and the bottom of the belt was really tight and the top was the right tension all this was after I adjusted the alternator.
srt4thatazz is offline
Old 08-28-2008, 12:34 AM   #2
Re: 89 turbo mini with ac delete bracket. wat belt do i use?
My Ride: 87 Shelby Z
Engine: 88 2.2 T2
Feedback: (8)
No different belts needed, the bottom will feel tighter b/c the belt distance is shorter than on the top. And yes the only adjustment is with the alternator.
moparfreak3 is offline
Old 08-28-2008, 12:40 AM   #3
Engine: 2.4, 2.5
Thanks for the info. So I can go to pepboys and ask for a belt for an ac model or just get the same belt that i just purchased that was for a non ac? Im sure your gonna say to get the non ac like I did but i just want to be clear. Thanks again.
Old 08-28-2008, 06:53 AM   #4
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
It doesn't matter which model the belt is for; it's the same belt.
Sittn86 is offline
Old 08-28-2008, 09:27 AM   #5
Engine: 2.4, 2.5
Ok, thank you both for the help.
Old 09-23-2008, 09:28 AM   #6
My Ride: Turbo Z28 & Minivan
need to do this also. what cars came with out the ac?
TurboZ28 is offline
Old 09-23-2008, 10:10 AM   #7
Um, any car that doesn't have A/C? Look under the hood.
Sittn86 is offline
Old 09-23-2008, 10:50 AM   #8
My Ride: Starion
one would think that would be the ticket, but if you dont know what a/c compressor looks like, even though its rightout in front of your face, that method may not work
how about if the heater control on the dash does not have an a/c button(s). that might be easier than opening the hood.
common cars to find without a/c are more prevelent in the northern areas.
omni/horizon, minivans, kcars, lancer/lebarron, shadow/sundance, acclaim/spirit/lebaron, are all common cars found without a/c
pobort is offline
Old 09-23-2008, 11:01 AM   #9
^You forgot e-body.
Sittn86 is offline
Old 09-23-2008, 12:49 PM   #10
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (10)
The 4 cyl. Dakota will also have the chance to be A/C delete. It will have the same A/C delete bracket. And there was one in a KC pick-n-pull that was A/C delete.
1983Rampage is online now
Loans | Mortgages | Bad Credit Mortgages | Debt Consolidation | Myspace Layouts
Page generated in 0.36833 seconds with 13 queries
