09-04-2008, 02:40 PM
Re: I Need Some Help Guys
My Ride: 1989 Daytona ES
Engine: 2.5l T2
the head assembly will bolt right onto the engine, you will have to change the AIS sensor to get it to work right, since they changed that from blow through and pull through throttle body. But it will work, there are plenty of early cars with the newer style intake.
For the pressure plate assembly, you wouldn't technically have to change them, but it would be a good idea, the T2/2.5l T1 clutch was a stronger clutch setup.
For the sticker, contact Rick (the admin) and he should be able to direct you in the proper direction.
