09-05-2008, 06:48 PM
Re: 1985 Shelby Charger Oil Pressure Questions
My Ride: shelby z
well, worst case is it has fried crank/cam bearings and you have to rebuild the engine, or a bad oil pump, which is not as bad as it sounds-they are not that hard to replace
-best case? you could get lucky, it's low on oil and what's in it is thin/low viscosity-any noises, at all? Does it have an idiot light and a gauge? The factory gauges are not great, and I found out that if you get the wrong sender unit/application, you think it's low when it is not at all. There is a brass junction block where an oil line can be tapped in to a mechanical gauge (front of engine, to the right of the distributor), if you have doubts you could hook one up fairly easily and check it out.
