09-06-2008, 11:06 PM
Re: 2.5 to 3.0 Questions
My Ride: 1994 Dodge Shadow
Engine: 2.5 T1
Ask anyone here, please don't try to turbo the 3.0L
Regardless, I'm not certain that the wiring harness going through the firewall will have the same connectors on it. Beware that you may have to cut the connector off and use the one from the Daytona by soldering it to the Shadows engine harness. I used a 1990 shadow engine harness in a 1994 shadow, and it used the same connectors, but different pinouts. I also tried using a 1991 LeBaron engine harness, after hours of getting the connectors wired on correctly I discovered there were just too many differences such as my car lacking a BCM (I think shadows do not have them?) among many other things.
I would strongly suggest getting an engine bay harness from the wrecker that is for a Daytona 3L. The auto headlights on the Tona require wiring that is not provided in the Shadow. Also, if u do get another harness, make sure to get all wiring rite up to the firewall, sometimes sub-harnesses in the engine bay wont match up.
Good luck
Reason: I can never get it rite the first time
