Old 09-15-2008, 10:38 PM   #1
Get a Mechincal oil pressure gauge!
Garrett Booster
My Ride: 00 TA WS6/85 Lebaron
Engine: LS1 5.7/ 2.2 TI
Induct: Nitrous
Most likely been beat to death, but my 85 Digital gauge Lebaron never moved off the notch above low. Even with a new sending unit. Cold or hot didn't matter.
Hooked up a Sunpro for 21 bucks tonight 60 lbs cold idle
15 psi HOT idle. 30 crusing at 65. 55ish at WOT under boost. 126,000 miles.
I would say that motor is still pretty tight.
Do your self a favor before you start going crazy like me and thinking bad motor or oil pump. The gauge saved me a lot of time and money.
LS1 Mike is offline
Old 09-15-2008, 10:55 PM   #2
Re: Get a Mechincal oil pressure gauge!
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
yup factory stuff is crap.
I run a sunpro on my red baron and will on all my unconcourse cars.
The blue baron stays original.
89 Blue Lebaron Premium- t1 automatic
91 Daytona-3.0 auto with blown tranny going 5 speed-FORSALE!
Old 09-16-2008, 01:50 AM   #3
My Ride: 85 GLH
Engine: 2.5CB
i have an autometer with an electronic sending unit, but i think thats gotta be better than stock equipment. anythings better than stock, they are just dummy gauges, pretty much a green for go and a red for "NO".
ZachT is offline
Old 09-16-2008, 08:00 AM   #4
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
ha, mine reads less than zero most of the time. New sending unit too.
dyno sheet
fmic install:
crazymadbastard is offline
Old 09-16-2008, 09:10 AM   #5
Garrett Booster
Induct: Nitrous
Those factory gauges are crazy wish I knew 10-15 years ago...
I guess when I started the Lebaron last night the oil was still warm because I went out and started it this morning cold pressure was over 70 PSI. With 126,000 miles and 22 years that boggles my mind.
LS1 Mike is offline
Credit Cards UK | Loans | Mobile Phone | Loans | Debt Consolidation
Page generated in 0.34760 seconds with 13 queries
