09-19-2008, 07:06 PM
Re: 88 2.2 head gasket replacment
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
You leave everything on the head including the turbo. Messing with the manifolds in-car is a total waste of time since it is not needed to change the head gasket. Get a friend to help lift the assembly unless you are big and hairy.
So basically drain coolant, remove the timing gear off the cam and zip tie the belt to the cog, remove valve cover, remove headbolts, remove turbo oil feed from front of engine, remove ac compressor(leave lines attached and swing to the side) remove the bolts on the ac bracket that go to the head(3 I think), get under car and remove turbo oil return hose/support bracket/downpipe bolts, remove turbo coolant line at block. remove fuel injector lines, vacuum lines, throttle cable/cruise.
My personal best is 45 minutes to strip down with air tools and bolts/tools flying everywhere. Probably 2-3 hours to put it back together carefully.
09-22-2008, 08:55 AM
My Ride: Daytona
so what I have been told is to get Part Number :P4452005
I picked up a felpro headgasket and will be returning that to use the mopar one.
Is this the right part for my 88 2.2 turbo 1?
Do I need different head bolts?
Reason: Added more info.
09-22-2008, 11:21 AM
#12
My Ride: 1987 Lebaron
Engine: 2.2L Turbo 2ish
i just pulled my head with the manifolds attached. I'd probably just pull the head with the turbo. It'll likely be easier. I wouldn't know though. I left my turbo in while i pulled the head.
And yes you'll need new head bolts. You can reuse the washers though.
That sounds like the right gasket. It's for the non cross drilled motors up to the year 1988, for tbi, and turbo 1. So you should be fine with it.
11-08-2008, 02:09 AM
#14
Yeah i somehow got the head out without removing the turbo. Believe me, I know I did it wrong; that its alot easier just to unbolt the turbo from the down pipe, but the bolts to the exhaust from the turbo had to be cut, and i couldn't reach them without getting the head out. Looking back on it i have no idea how the hell I got that head off.
