09-19-2008, 08:56 AM
Re: rad fan not working again
My Ride: Starion
could be a bad relay, a wiring problem, a pcm driver problem. you need a scanner, a wiring diagram and a dvom to properly diagnose this problem. (can be done without a scanner but it's a lot easier with one)
you need to verify that you have 12v power to the relay (gray wire), you need to verify that if you jumper main relay power to the fan (grey to light green), see if the fan comes on. engine running, disconnect ECT (engine coolant temp sensor -OBD2 current terminology) see that you have relay control power dark blue and pink wire, see if the control gounding wire has continuity (zero ohms resistance between wire and negative battery post)
