Old 09-20-2008, 07:08 PM   #1
Sloppy Cables
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
After replacing my head gasket, I now have a lot of play in my throttle and kickdown cables. The throttle has an inch alone before going into the cruise control module. If I put my foot to the floor, the actuator lever sticks and holds at WOT.
Is there some way to adjust this slop?
The car is a '94 Acclaim 2.5 N/A auto, A/C, cruise control.
Moparmonster is offline
Old 09-20-2008, 07:28 PM   #2
Re: Sloppy Cables
My Ride: Starion
Originally Posted by Moparmonster View Post
After replacing my head gasket, I now have a lot of play in my throttle and kickdown cables. The throttle has an inch alone. If I put my foot to the floor, the actuator lever sticks and holds it at WOT.
hate to say it but you messed up something on the assembly. there is no adjustment. i'm sure is was fine before you fixed it now there's something not put together the same way it was before you took it apart. check your cable routing, check the bracket is properly installed, that you didn't mix up cable locations, and so on
pobort is offline
Old 09-21-2008, 03:58 PM   #3
Re: Sloppy Cables
The braket only goes on one way, and the cables can't really routed incorrectly without causing a major bind in them. It literally seems as though the cable is now longer than when I started, impossible as it is.
I have Gary Gokey coming tomorrow to look at it.
Old 09-22-2008, 10:09 PM   #4
Re: Sloppy Cables
How about that? Gary stood me up and I've gotten absolutely no help here.
The car's going to the scrapper tomorrow since it can't be repaired.
Thanks guys, I appreciate everything.
Old 09-23-2008, 07:12 AM   #5
Re: Sloppy Cables
My Ride: Starion
oh good, then you wont have to post about it's problems anymore
pobort is offline
Old 09-23-2008, 09:10 AM   #6
Re: Sloppy Cables
My Ride: Daytona
wow just cause there is a throttle cable issue it goes to the shredder.
mrjoecanadian is offline
Old 09-23-2008, 12:42 PM   #7
Re: Sloppy Cables
You don't understand; there's no way there should even be such a problem. There's no adjustment, so when I put everything back together, it's now an inch longer than when I started, which means I have almost no pedal at all.
I've had nothing but problems with this car and I've just about had it. I came here in desperation, but I got no help. If you'd like to come and look at it, you're welcome to it. Otherwise, I have absolutely no idea what the problem could be.
Old 09-23-2008, 05:05 PM   #8
Re: Sloppy Cables
My Ride: Starion
welcome to owning a quality american made car.
now for your problem. it's quite apparent that there is some kind of assembly error. it was fine before you fixed it. seems like it's time for you to back off, let someone else look at it. or go find another similar car and see how that is put together. maybe this will make the problem more clear.
pobort is offline
Old 10-21-2008, 03:43 AM   #9
Re: Sloppy Cables
Okay, Gary did finally come through for me. We got the cables sorted out, the brakes bled, the timing marks set up, and the thing put back together. The only remaining problem is the timing at the distributor; I can't time it because it has an aftermarket torque convertor with no marks. The car will go back to the shop on Friday for fine tuning. He's family, so he probably won't charge me.
This is my hobby? This is what I enjoy? There's definately something wrong with me.
Old 10-21-2008, 08:36 AM   #10
Re: Sloppy Cables
My Ride: Starion
damn, you fixed it now you're going to be posting more and more problems
so how did you solve the problem, what was the cause of your threat to junk the car (or were you just crying wolf)
i really hate when people post a problem but never post a solution so others can learn what can happen if..... and how to fix a problem by ....
post your findings and results!!!!
pobort is offline
Old 10-22-2008, 02:35 AM   #11
Re: Sloppy Cables
No, I was just enormously frustrated when I posted that, although I did threaten to set it on fire at one time, too.
I'm sure I'll have more problems to address in the very near future.
Old 10-22-2008, 06:53 AM   #12
Re: Sloppy Cables
My Ride: Starion
so, what's the answer to how you solved the problem you posted you were having all these problems with the cables, what was wrong, how was it fixed.? help someone else that has this problem or help others to prevent the same issue.
pobort is offline
Credit Card Debt Consolidation | Classical Homeschooling | Credit Cards | Loans | Credit Cards
Page generated in 0.48532 seconds with 13 queries
