Old 09-24-2008, 12:02 PM   #1
Starting system schematic T1?
Garrett Booster
My Ride: 86' Laser XT
Engine: 2.2L Turbo I>II
Does anyone have a schematic for the starting system on a T1 car? The car is an 86' Laser XT, and occasionally will not turn over. I've eliminated the starter, starter relay and ignition switch.
Does the neutral safety provide a ground directly to the starter relay? Or does the ECU provide a ground to the relay coil via a signal from the nuetral safety switch? I'm getting the following to the relay: Constant 12v and ignition 12v but no 12v on the output side of the relay to the starter.
I have yet to provide my own ground to the relay.
Thanks for your help!
pooty is offline
Old 09-25-2008, 10:46 AM   #2
Re: Starting system schematic T1?
Garrett Booster
Anyone? NAJ?
pooty is offline
Old 09-25-2008, 08:50 PM   #3
Unfortunatly I lost my Alldata connection and do not have the wiring you need.
The only starter circuit I have is 1990 if you think it will help, the wiring colors/connectors are probably different but the system probably operates the same way.
If you think it may help I will post it.
Old 09-26-2008, 05:36 PM   #4
Ultimate Credit Card Guide | Buy Anything On eBay | Free Ringtones | Personal Finance | Debt Consolidation
Page generated in 0.35198 seconds with 13 queries
