09-29-2008, 07:37 AM
Re: 2.4 cams. shims for the lifter.
My Ride: Starion
I haven't done this exact engine, but on other overhead cam follower type heads, what I was looking for when it came to preload on the lifter is I would collapse the lifter and see how much lash I would have between the follower and the cam base circle. I would like to see .030" clearance. be aware that if you shim the lash adjuster, you raise the back of the follower which increases angle on the follower when the valve is open. when i used reground cams, lift is increased by reducing base circle... this causes clearance between follower and cam (lash), to properly correct this and have correct follower geometery, I needed to use a longer valve and shim the lash adjuster. basically i was raising the follower the same amount on both ends.
