Old 09-27-2008, 09:37 PM   #1
broke my cam shaft...
My Ride: 89 daytona shelby
Engine: Gas 135
Well today my cam shaft broke into 2 pieces... right between #1 cyl intake and exh valve.
i was wondering if anyone in the charlotte area has a 2.2 T2 head just lying around collecting dust they wouldnt mind getting rid of for a fair price. I really dont have the money at the moment to do a total rebuild like i want. I dont want to see my car get parted out, as she has treated me well and its only right to do the same in return.
The car is an 89 daytona shelby 2.2 T2 manual.
Thanks
Steven
89'tonakickin is offline
Old 09-27-2008, 10:07 PM   #2
Re: broke my cam shaft...
My Ride: 1987 caravan
Engine: 2.2 carb
Broken shaft is caused by too much tension. This either was improper timing belt tension or head rebuild process was machined badly that camshaft journals is not parallel with head's deck that timing belt "walks" towards head at correct tension. Some "quickie" fix put extra tension on the belt to mkae it center away from the head. Bad fix.
That is reason I advise finding good head rebuilder that straightens warped heads FIRST before doing final light cut on the head's deck in PARALLEL with the camshaft journals. Very important and often not done properly.
Cheers, Wizard
Wizard is offline
Old 09-27-2008, 10:12 PM   #3
Engine: Gas 135
no the blame is all mine i had to do something a while back with the timing belt and i guess i put too much tension on it...oh thats right had to change the water pump thats why the belt had to come off..
Old 09-28-2008, 06:37 AM   #4
My Ride: Starion
uh why would you take off the timing belt to change the water pump
pobort is offline
Old 09-28-2008, 08:05 AM   #5
Engine: Gas 135
if i remember right the intermediate shaft gear covers 1 or 2 of the bolts for the water pump...thats why
Old 09-28-2008, 08:40 AM   #6
My Ride: Starion
huh, i just took 4 bolts off and pulled the water pump assembly off the engine then changed the pump. seemed i didnt need to touch the timing belt or even remove the timing belt cover. sounds like an awfully hard way to change a waterpump.
pobort is offline
Old 09-28-2008, 10:28 AM   #7
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
what is wrong with just swaping in a new/used cam?
dyno sheet
fmic install:
crazymadbastard is online now
Old 09-28-2008, 11:30 AM   #8
Engine: Gas 135
i was doing 75 when the cam broke, so i was spinning pretty good. the cam shaft wore a groove in the middle of the bearing surface and chewed up the side of the bearing to the point of having a nice lip...ill get some pix later today
EDIT: my water pump has 9 or 10 bolts that hold it on...how does yours only have 4? i mean my mark 8 has 5 or 6 but that sits right in front between the heads...did different year engines have different water pumps?
Old 09-28-2008, 12:37 PM   #9
Mo' valves, mo' boost
jonnymopar's Avatar
My Ride: Daytona ES
Engine: 2.4L DOHC
Did you change the water pump with the housing still attached to the engine? Yes, different years had slightly different water pumps, but I believe they all use the same housing.
Jon J.
1989 Daytona ES 2.4L - MPH (and, turns out, MPG too!!)
2003 Neon SXT - MPG... yeah just MPG
jonnymopar is offline
Old 09-28-2008, 03:43 PM   #10
Engine: Gas 135
mine looks like a squash...ewww i hate squash...on mine i see no way only 4 bolts hold it on unless ur talking about the BIG housing attached to the block which i see no reason to take that huge thing off unless u remove the motor and rebuild it...
Debt Consolidation | Overstock.com | Advertising | Credit Card UK | Payday Loan
Page generated in 0.36152 seconds with 13 queries
