10-02-2008, 11:37 PM
#21
Re: has anyone done a TII swap w/out pulling the head?
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
well I did the conversion on my (formerly carb'd) 86 omni
IF you do the swap right and dont F up any wiring - then its pretty much plug&play since you are using all stock parts including the calibration
most people who have had difficulty - including myself - had problems with MISTAKES which were made in the process, or installed used parts which turned out to be faulty, sometimes those can be a bit tricky to track down
example - PO had slid the rad over to make room for the IC; it was about 1/4 inch from the alternator; (once I got car running) when I did a hard launch the fusible link would blow; took me couple hours (OK - it took me about 4 hours) to find that the engine was torqueing and rocking the alternator field wire into the brass rad end tank
was that a problem with the TII conversion ? well, yes, but it was a MISTAKE made by the PO (I swear it wasn't me!)
