Is there a remedy for High NO ppm? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 10-01-2008, 08:59 AM   #1
Question Is there a remedy for High NO ppm?
My Ride: '85 Plymouth Horizon
Engine: 2.5L TII
moparjim is keeping the peace
I had my 1992 spirit ES 2.5L turbo e-tested yesterday and she failed. Everything was great except for the NO ppm. They were at 924 when the limit is 467. I have no idea where the timing is because the whole is really hard to see without spending 25 minutes taking all of the air cleaner parts off. Other than that it runs quite well. The cat looks recent also. I think high compression and advanced timing causes high NO ppm readings, but there might be more? Any help is appreciated. Thank you
moparjim is offline
Old 10-01-2008, 09:26 AM   #2
Re: Is there a remedy for High NO ppm?
My Ride: SOLD!
Gutfeeling is keeping the peace
You mean NOx? Sorry it's been a while since I had my emission course plus there's no testing over here.
I suggest running higher octane (*unleaded of course) and go at it again.
Gutfeeling is offline
Old 10-01-2008, 10:42 AM   #3
My Ride: Turbo Minivan
Engine: 2.5L
ibrake is keeping the peace
Cam timing, spark timing, make sure there is no vacuum leaks, ... etc...
ibrake is offline
Old 10-01-2008, 11:01 AM   #4
My Ride: 90 shelby
90 shelby is keeping the peace
NOX= cat or EGR so you dont have EGR you will need a CAT
90 shelby is offline
Old 10-01-2008, 11:28 AM   #5
Engine: 2.5L TII
I thought it was NOx, but the sheet says "NO ppm" as in Parts Per Million I would assume. I unplugged the temp sensor and was able to read the timing. It was at 14-15 degrees... so I set it at 10 right now to be safe because the emission sticker says to set it at 12 degrees. I also ran a can of combustion chamber cleaner through it. She seems to run a bit better now. The cam timing is correct, i checked it when i took the engine out a month ago. I also replaced some vacuum hoses before and made sure the system was to stock setup. It has about 1/4 tank of gas from January in it, but i put another 1/4 tank of premium in it yesterday.
moparjim is offline
Old 10-01-2008, 11:39 AM   #6
My Ride: 86 glh turbo
Engine: t2 2.2l intercooled
dirtyglhturbo is keeping the peace
i do this crap every day. 90 shelby is 100% correct. egr problem if equipped, prolly not. it needs a converter. btw what was the co content? you have to watch out, if co is borderline, it may go up when the converter is changed and nox is down. pm me if you need advice
dirtyglhturbo is offline
Old 10-01-2008, 03:05 PM   #7
Engine: 2.5L TII
I just got back from the test centre and she passed! just barely, but does it matter? I ended up taking a little bit more timing out to around 8-9, ran crappy for the test, I just put it back after. Test 1 was at 14 degrees, test 2 is at 8-9 degrees after running a can of Motomaster "engine tune up" through vacuum.
40km/h- Limit test1 test2
HCppm 62 29 35
CO% .35 .02 .04
NO ppm 467 924 438
Curb idle- Limit test1 test2
HC ppm 200 25 33
CO% 1 0.0 0.0
Thanks for everyone's comments. Now I just need to get it aligned, tires swapped, get rid of the old car :)
moparjim is offline
Old 10-01-2008, 03:28 PM   #8
TD Extreme User!
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (23)
crazymadbastard is keeping the peace
Oh- I usally let the tank run very low and add a couple cans of "dry gas" and some say remove the air cleaner element.
crazymadbastard is offline
Old 02-04-2009, 01:43 AM   #9
My Ride: 2000 Dodge Caravan
Engine: 2.4 DOHC
Christ is keeping the peace
This is kinda old, but running lean causes high NOx emissions... (also NO, same thing, afaik.)
"Lean" in this case is referring to stoich... if you're leaner than stoich, and all else is OK, there's a good chance you're putting out more than your share of NOx particles.
Christ is offline
