10-09-2008, 10:25 AM
Sport Compact Car Junkyard Warrior
Wickedly Boosted
My Ride: 1987 Omni T2/A-555
Engine: 2.2 T2
Sport Compact Car had an issue in September of 2005 titled "Budget Bad-boys" It featured a CRX, A 1st gen DSM, and ofcorse my favorite, a Dodge Omni. The builder claimed to run 11.5's all day long for less than 4 grand and that included the price of car. All i remember was that he was using a 2.5 (for torque) and one really strange item... GM J-Body Axles that have "proven trouble free for dozens of passes." Does anyone know any more information about this set-up? Does anyone actually have that issue that could include the parts list? Is there anyone actually running GM axles in their L-body?
10-09-2008, 10:31 AM
Re: Sport Compact Car Junkyard Warrior
My Ride: 85 GLH
Engine: 2.5CB
i have that issue, ill look it up tonight.
IIRC, hes running 12.5's, 568 tranny, t3/t4 turbo, and 25psi.
10-09-2008, 10:52 AM
My Ride: 87 Shelby Z
Engine: 88 2.2 T2
the guy is on here I forget what his screen name is but here is the parts list.
-2.5L
-ported head with 1mm os and back-cut valves, custom roller cam
-TU T3/To4 stage 2 turbine, 0.63 a/r ex, 50-trim compressor
-Mk 3 supra i/c, 2" i/c plumbing, 1g dsm bov, 52mm tb, ported two piece intake
-3 bar cal by TU w/756cc injectors, s60 fuel pump, afpr, champion RN9Y plugs
-A568 tranny with dual-diaphragm press plate and quaife limited-slip and 3.85 fd
-10.25 disc brakes all the way around
-HP @ the wheels 321@5000
-Torque 341@4900
-Weight 2440 lbs
-Quarter mile 12.9@113
This issue stays with me at work for all the haters
10-09-2008, 11:48 AM
Wickedly Boosted
Engine: 2.2 T2
Very sick. It does say GM J-body axles right? I'm currently in a bind with my project, and its looking like it will face hibernation before completion. 87 Omni with a T2/A-555 pulled from an 88 Shelby Daytona. And neither the omni nor the daytona axles fit correctly...
10-09-2008, 11:52 AM
My Ride: 1989 Daytona ES
Engine: 2.5l T2
you are needing to get a hold of a set of 88-90 Automatic L-body axles. 87-88 was the transition period from the small spline to the large spline transmission shafts. So you need the 88+ axles from an omni. And the manual ones will not work since they were still small spline.
10-09-2008, 11:59 AM
Engine: 88 2.2 T2
Yes it says that he used GM j-body axles but they were customized to use with the td tranny and hubs.
10-09-2008, 12:03 PM
My Ride: 85 GLHT, 87 ShelbyZ
10-09-2008, 12:32 PM
Engine: 88 2.2 T2
Yeah thats him and BTW he was running 20psi with a 3:1 mix of 91 octane and c-16
10-09-2008, 12:42 PM
Wickedly Boosted
Engine: 2.2 T2
So, i assume i'm not the only SCC reader on the forum.  Yeah, his omni was what swayed me from building a 350 Chevette and a Turbo Venture swap Cavalier. Kids in my town all rock JDM, I traded my Camaro for an 88 Yota Pickup and saved the rest of the money for my Omni project. Since september of '05 i have been scouring for information, parts, build ups and ofcorse, the base Chasis. Well, i didn't find mine until late '06 (When it was sitting behind the garage that i hired to spray a liner in my truck, days away from the crusher). Anyway, Thank you all for your constant help and support. The project is shaping up much better than i ever thought possible. Any additional information on Boyd's Omni is greatly appreciated, It may seem odd, but i am a big fan of the car.
10-09-2008, 01:23 PM
Hybrid Booster
My Ride: 86 GLHT
Engine: 2.2 TI Intercooled
If you want to keep the equal length axels make sure to get two drivers side axels from an 88-90 Omni automatic. This is the setup my brother has in his 84 Omni with a 555.
10-09-2008, 02:15 PM
Wickedly Boosted
Engine: 2.2 T2
Okay, that Sounds good, Any modification necessary?
10-09-2008, 02:26 PM
#12
Hybrid Booster
My Ride: 86 GLHT
No it shouldn't take any modification, if you don't want to use the equal length axels you could just use the long passenger side axel from the 88-90 automatic Omni. There are other modificatons necessary for putting the 555 in an L-body though. You will either need to put the cable shifter in the L-body(which my brother did to his 84 Omni) or do what we did to mine(rod shifted with Heim joints).
10-09-2008, 02:57 PM
#13
Wickedly Boosted
Engine: 2.2 T2
Already planning on putting the cable shifter into her. Purchased a full 88 Daytona for this swap. Forgive me for sounding stupid, but, if i use two driverside axles, won't i be lacking an intermediate shaft?
10-09-2008, 03:02 PM
#14
Hybrid Booster
My Ride: 86 GLHT
If you use the two drivers side axels you will need to use the intermediate shaft out of the 88 Daytona if it had one or any vehicle that came with the larger sline intermediate shaft. Other wise just use the long passengers side axel from the 88-90 automatic Omni.
10-09-2008, 03:05 PM
#15
Wickedly Boosted
Engine: 2.2 T2
Thank you very very much. She should be quite the sleeper.
