Old 11-21-2008, 05:30 PM   #1
i just found this "estimate your horsepower"
Horsepower Calculator, calculate hp from et, trap speed, calculate tire diameter, mph and rear end ratio.
click on it
daytonafastback is offline
Old 11-21-2008, 05:49 PM   #2
Re: i just found this "estimate your horsepower"
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (7)
Images: 32
perty interesting!!!
thanks for posting it
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is online now
Old 11-21-2008, 05:59 PM   #3
My Ride: 86 daytona cs
Engine: 2.2 t1
Images: 3
Wow that's actually pretty accurate. I put in 2800 lbs for my 86 daytona and 16.4 1/4 mile time and it said 150chp.
thedon809 is offline
Old 11-21-2008, 06:14 PM   #4
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
I always use the TCI calculators since it has converter slip, ect..
Link
speeduphoria is offline
Old 11-21-2008, 07:32 PM   #5
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
there are quite a few Hp calculators out there.. using various formulae and assumptions.. I've run the same e.t./mph/wt thru 3 different and got 30 Hp different answers - so I averaged
heres a good page ; warning - has some math !
http://www.ajdesigner.com/phphorsepo...horsepower.php
detobias is offline
Old 11-21-2008, 09:51 PM   #6
My Ride: 84 Turbo Z, more
Engine: 2.2-2.5
Link
How do you figure convertor slip?
4Daytonas is online now
Old 11-21-2008, 10:07 PM   #7
Engine: 2.4 DOHC
You use the calculator, lol
If your talking about the formula, it lists it under where you input the data
Old 11-22-2008, 10:04 AM   #8
Engine: 2.2-2.5
Yeah thanks I didn't see it first time around. my 9"J figures less than 2%
Old 11-24-2008, 12:02 AM   #9
My Ride: (2)91 Spirit R/T's
Engine: 2.2 TIII
Images: 27
seems to be decently accurate too
Simsy is offline
Debt Consolidation | Bankruptcy | Refinance | Bankruptcy | Loans
Page generated in 0.38044 seconds with 13 queries
