05-20-2003, 09:14 AM
Re: Help engine jumping timing!
My Ride: 88 CSX-T
Engine: 2.2 T1
Originally posted by athlon420500
when I go to set the distributer it jumps timing on me I cant get it to set right any ideas?
Just out of curiousity - when you are setting the ignition timing, you are unplugging the coolant temp. sensor right? If you don't, the timing on the flywheel will jump around and not stay in a fixed position.
Not trying to be a smarty-pants, but just want to make sure it isn't something easy..
