11-29-2008, 11:16 AM
Re: what head gasket?
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
call Cindy at FWDperformance.com they will know the gasket that you need, its special since you are using o-rings.
and i'd go with getting the ARP studs, they hold up way better than anything else....
and since you are new...check out this site for lots of random little info
http://www.thedodgegarage.com/
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
